Software > Software
sonar algorithm
(1/1)
vbnandu86:
i m planning to buid a robot that uses sonar,initially i have planned for it to be stationary and detect objects in its(sonars) range.
My problem is to find an algorithm that can distinguish objects on a plane perpendicular to the (sonars) cone's apex.meaning if there are 2 objects on the same plane it has to identify obj.1 is at co-ordinate say 0,20 and obj. 2 is at 10,20
Please help!
hgordon:
It would be helpful for you to describe the problem in polar coordinates rather than cartesian coordinates.
Take a look at the specs on the sonar unit - what is the beam width (in degrees) ? Also, does the receiver only return a signal corresponding to the distance to the closest object, or does it process multiple bounced signal returns ?
If you have the possibility of steering the sonar beam, you can build a model which helps differentiate between objects. Take a look at the tutorial on sonar on this website -
http://www.societyofrobots.com/sensors_sonar.shtml
Navigation
