Author Topic: Problem with my Syren Controller?  (Read 1774 times)
Offline silo_xtremeTopic starter
  • I really love robots, they keep me awake at night.
« on: May 20, 2009, 12:32:17 PM »
I have a Syren25 and when the S1 wire is not connected to the Syren the motor is off.
When the Syren25 has a S1 wire connected to it, and the other end of the S1 wire is not connected to anything , the motor runs.
It's also not responsive to any commands.
I have it in Simple Serial mode.  I'm thinking my Syren has a short in it ..... would this be a correct thought? ???
Re: Problem with my Syren Controller?
« Reply #1 on: May 23, 2009, 10:35:30 PM »
lol sounds like the wire is somehow acting as an antenna . . . check to make sure your grounds are common, and that your other wiring is correct.
« Reply #2 on: May 24, 2009, 09:08:25 AM »
LoL, I know it's an interesting problem.
My 5V source and 24V source are separate power sources, isolated from each other.  I had another interesting problem when I tried to use the 5V output on the Syren ... I ended up with 33V as an input into the Syren.
I think there's something wrong with my Syren's ... but I need a sanity check.
« Reply #3 on: May 24, 2009, 09:52:16 AM »
As I suspected, you need to keep grounds common. :P
« Reply #4 on: May 24, 2009, 10:09:27 AM »
 Haha, That looks like it fixed the noise problem!  Thanks!!!  ;D
Now how come my code won't turn it off after it starts?
// USART2 initialization
// Communication Parameters: 8 Data, 1 Stop, No Parity
// USART2 Receiver: Off
// USART2 Transmitter: On
// USART2 Mode: Asynchronous
// USART2 Baud Rate: 38400
UCSR2A=0x00;
UCSR2B=0x08;
UCSR2C=0x06;
UBRR2H=0x00;
UBRR2L=0x19;
                UDR2=190;
                delay_ms(1000);
            UDR2=127;
while(1);
I'm a bit confused on that one.
« Reply #5 on: May 24, 2009, 10:13:21 AM »
What mcu you using? :P
« Reply #6 on: May 24, 2009, 10:14:30 AM »
Heh, Sorry.
ATMEGA 1280
I don't get any response or change in direction either  ... I can just turn it on with a signal.  It's weird.
« Reply #7 on: May 24, 2009, 10:19:11 AM »
Reverse the 190 and 127 . . . that'll offer a clue to what isn't working.
« Reply #8 on: May 24, 2009, 10:22:45 AM »
The motor turns on as soon as I hit the program chip button.
In order for me to get the motor to stop, I erase the chip and cycle the power to both the chip and Syren.
« Reply #9 on: May 24, 2009, 10:24:12 AM »
This means either your wiring still isn't correct, or your UART isn't working as you thought.
Got an oscope?
Also, attach your uart to hyperterminal to see the actual output.
« Reply #10 on: May 24, 2009, 10:28:53 AM »
No Oscope, suppose I should buy one.
Will try to get the USART to hypertem soon.
I've been trying to do everything on the JTAG interface ,....  I can debug the chip..
« Reply #11 on: May 24, 2009, 10:45:27 AM »
What should I look for with an Oscope or USART to Hyperterm?
« Reply #12 on: May 24, 2009, 11:19:20 AM »
If its hyperterminal, you should see numbers representing what you sent to serial of your Syren.
If an oscope, you'll see a TTL binary of the number (square wave, high for 1, low for 0). Just use the trigger setting to capture it.
Offline sonictj
  • Helpful? 11
« Reply #13 on: May 24, 2009, 02:58:15 PM »
you should see the equivalent ascii character not number. you will have to convert to see the equivalent number.
« Reply #14 on: May 25, 2009, 10:26:26 AM »
Just thinking.
I could try packetized serial mode with address 128.
Would this be the correct code to send 1 packet and test this concept?
UDR2=128;
                UDR2=127;
                UDR2=64;
                UDR2=((128 + 127 + 64) & 0b01111111);
« Reply #15 on: May 25, 2009, 05:45:42 PM »
I personally recommend just using AVRlib. Its code that you know works, and its user friendly.
Last post January 09, 2009, 07:21:27 AM
Last post July 30, 2010, 09:05:38 AM
Last post January 04, 2011, 02:12:49 AM
by averafter
Last post January 19, 2012, 11:30:03 AM
by fish_man
