Author Topic: Dice-o-Matic  (Read 1429 times)
Offline AdminTopic starter
Dice-o-Matic
« on: May 26, 2009, 10:28:36 AM »
As you know, computers can't actually generate random numbers. So what do you do if you need hundreds of random numbers per second?
In all, it takes about 13 seconds for an individual die to make a round trip. There are 200 dice in the machine, each rolling four times a minute, totaling over 1,330,000 rolls a day.
The dice are "Michigan Red Eyes", which have different colored pips for each value. The different colors make it pretty easy to count rolls. For example, if 6 yellow dots are found in the image, there were three 2s rolled, no need to worry about determining the proper grouping or orientation of pips.
Of course, I would have done the ADC + static noise method, but still this is pretty neat . . .
http://gamesbyemail.com/News/DiceOMatic
Dice-O-Matic
Re: Dice-o-Matic
« Reply #1 on: May 26, 2009, 02:36:19 PM »
that is... errr.... confusing...
what would be some uses for this machine?
Re: Dice-o-Matic
« Reply #2 on: May 26, 2009, 05:16:34 PM »
Casinos to generate random numbers. Guys at MIT have cracked electronic random number generators to predict what the next number would be.
Offline hoosier122
Re: Dice-o-Matic
« Reply #3 on: May 27, 2009, 04:58:29 AM »
Dice-O-Matic
Yep computers use the current time to calculate "random" numbers.
Random does not exist, ever.
Offline ddemarco5
Re: Dice-o-Matic
« Reply #4 on: May 28, 2009, 05:08:40 PM »
Wow, that is a fast video processing algorithm.
Re: Dice-o-Matic
« Reply #5 on: May 29, 2009, 02:14:41 AM »
that kinda sucks that computers use the current time to generate random numbers...
so were the guys from mit using their info for bad?
Last post March 31, 2008, 01:13:24 PM
by Trumpkin
