Author Topic: Extending Range of Infrared Detector  (Read 2051 times)
Offline airman00Topic starter
« on: May 27, 2009, 06:19:41 PM »
SETUP:
standard T-1 3/4  IR LED with 220 ohm resistor connected to 5V power source
IR Phototransistor ( the QRB1134 ) in this circuit - http://www.superdroidrobots.com/product_info/qrb1134.htm - with a voltmeter monitoring the signal
QRB1134 - http://www.superdroidrobots.com/product_info/QRB113x.pdf
Neither the LED nor the phototransistor use a modulate IR signal. They are just ON.
GOAL:
I want to be able to detect IR light that is emitted by an IR LED with a IR Phototransistor. I don't want to send any data, just need to be able to detect the light. I want to be able to detect the IR Light from 6 feet away.
TEST:
I am trying to see how far away I can move the phototransistor from the IR LED and still get a signal. I point the IR LED at the IR Phototransistor , use a cell phone camera to verify that the IR light is hitting the phototransistor, and then see if I get any signal at all from the phototransistor.
PROBLEM:
I do get a signal when they are 1 foot apart, but passed 1 foot I do not get any signal. What can I do to increase this range?
I know further range is possible because TV remotes have ranges farther than 6 feet!
Re: Extending Range of Infrared Detector
« Reply #1 on: May 27, 2009, 06:58:46 PM »
Look into higher power IR leds?
Also there are often those IR screens in front of the LEDs (red semi-transparent), maybe those have an impact on the IR signal - maybe mess around with those.
Offline Rebelgium
« Reply #2 on: May 28, 2009, 05:05:36 PM »
It is certainly possible.
Try using a IR receiver from a TV/VCR/...
Use a voltmeter to measure the output of it, and when you know what kind of voltages to expect you can design firmware for a µC, or a circuit with opamps to convert it to TTL level.
orgcrime.net
« Reply #3 on: May 28, 2009, 05:46:56 PM »
I figured it out - keep the IR LED's voltage at 5V and increase the IR phototransistors voltage to 12V. Works well now, especially with a comparator.
« Reply #4 on: May 30, 2009, 12:14:45 PM »
Reading your other post:
http://www.societyofrobots.com/robotforum/index.php?topic=8042.0
I suspect what you really want is a laser diode . . .
http://www.mouser.com/Search/Refine.aspx?Keyword=laser+diode
You can also hack them out of old cd/dvd players. Don't forget eye protection!
If not that, would about modulation at 38KHz? And is there environmental noise?
« Reply #5 on: May 30, 2009, 01:28:01 PM »
I'm using IR detectors to locate this IR ball - http://www.acroname.com/robotics/parts/R194-ROBO-BALL.jpg
« Reply #6 on: May 30, 2009, 01:32:58 PM »
OH! should have said that earlier :P
interesting . . . doing any amplification on it, by any chance? What range you now getting?
Last post November 04, 2007, 07:49:13 AM
Last post March 31, 2008, 05:34:41 PM
by airman00
Last post June 19, 2008, 02:25:24 AM
by bens
Last post August 14, 2008, 12:56:00 AM
by sonictj
