Author Topic: 50 Euro robot  (Read 7773 times)
Offline breemenTopic starter
50 Euro robot
« on: April 02, 2007, 01:53:36 AM »
Hi people!
I'm just new on this site and want to introduce myself to you. My name is Albert van Breemen and I'm from the Netherlands. A few months ago I started a website on robots called http://www.personalrobotics.nl. I publish all my projects on this site.
My latest project is the '50 euro robot project'! But I saw that also a $50 robot project exists on this site ;) It seems that we all want the same: have fun with robotics but for an affordable price! I will soon start publishing more information on how I manage to build a robot for 50 euros. Meanwhile I have a short movie on the results so far published at http://www.personalrobotics.nl.
cya,
Albert
check http://www.personalrobotics.nl for the latest news on robots
Re: 50 Euro robot
« Reply #1 on: April 02, 2007, 02:48:45 PM »
Im traveling Europe right now so I was a bit amused by the 50 euro title . . .
Some of the members to this site are located in europe, and often mention frustration with the fact that it costs more to buy robot parts within europe (shipping, for one thing). I think you have a challenge ahead of you :P
Keep us updated! Im interested in how others would approach the same problem.
Offline Brandon121233
Re: 50 Euro robot
« Reply #2 on: April 02, 2007, 04:00:45 PM »
Hey Albert
I saw that in your 50 Euro robot video you are using the Arduino board, I'm planning on getting that for a robotics project that I plan to enter in this sites tutorial contest, I was wondering how well suited the Arduino is for robotics applications; like is the software user friendly, and does the board look likes it put together pretty well? Your the first person that Ive seen make a working robot with the Arduino.
Hell, there are no rules hereŚwe're
        ŚThomas Edison
Re: 50 Euro robot
« Reply #3 on: April 03, 2007, 01:49:03 AM »
Admin: Enjoy traveling Europe and if you're near Eindhoven in the Netherlands just send me a message! That's were I work and live!
By the way, I indeed bought my parts in the USA because it was cheaper.
Brandon:
The Arduino board is very VERY easy to use. One problem I had was with the USB driver that came with the software on the Arduino site. But I went to the official site of the chip manufacturer and downloaded the latest driver version. An other problem I currently have is when the board gets its power supply not from USB but from a battery, the program won't start. I have to mention that I'm just jusing the board for 2 days now and I do not read many manuals  :o  maybe I should  :)  The board is cheap and has sufficient I/O possibilities for a simple project like mine.
I hope to finish my article/report soon and I will publish it on my website (but will also let you know here!)
Albert
Re: 50 Euro robot
« Reply #4 on: April 09, 2007, 12:25:32 PM »
Hi there!
Today I published the first part of the 50 Euro Robot project! Check http://www.personalrobotics.nl/mambo/index.php.
Have fun!
Albert
Offline sotu
  • ´BB - Eye Biped Bot
Re: 50 Euro robot
« Reply #5 on: April 09, 2007, 01:13:10 PM »
Is the driving mechanisme one of theese with wheels: http://www.pololu.com/products/tamiya/0061/ ?
And if it is can u both drive and turn with it? Couse the front wheel is just a support wheel right?
How to build a biped bot:
Offline ed1380
Re: 50 Euro robot
« Reply #6 on: April 09, 2007, 03:07:31 PM »
Use some common sence. look at the diagrams. Each wheel has it's own motor and gearbox. so you can do a diferential drive with it.
Re: 50 Euro robot
« Reply #7 on: April 09, 2007, 11:06:13 PM »
Hi Sotu,
Yes I've used the Tamiya 70097, the one you gave a link of. There are three configurations of how to assemble this gearbox, but only configuration results into two independently controlled wheels! This is the 'C-type' configuration. The A and B type configurations result in high speed of the wheels, but both turn in the same direction. The C-type result into 'low speed' (fast enough for me) with two independent wheels.
Albert
Offline sotu
Re: 50 Euro robot
« Reply #8 on: April 10, 2007, 01:03:17 AM »
Okey thanks..:D So u have to do something with the gearbox after u have ordered it right?
Re: 50 Euro robot
« Reply #9 on: April 10, 2007, 01:52:13 AM »
Please have a look at my full article http://www.personalrobotics.nl/mambo/index.php?option=com_content&task=view&id=106&Itemid=84 and have a look at figure 5. Here you see all parts you get when ordering the gearbox.
I ordered at Sparkfun, which was the cheapest!
Albert
Offline sotu
Re: 50 Euro robot
« Reply #10 on: April 12, 2007, 10:13:14 AM »
Can the gearbox turn? Is there 2 seperate sticks each driven by 1 motor each? So only left side of the visible metal stick can drive forward and the right bakcward or the opposite making the gearbox able to turn?
Re: 50 Euro robot
« Reply #11 on: April 12, 2007, 11:18:18 AM »
Yes, there is one configuration (called type "C") in which each stick is driven by a seperate motor, so the gearbox can turn!
Albert
Offline sotu
Re: 50 Euro robot
« Reply #12 on: April 12, 2007, 01:10:25 PM »
Is the type called "C" a pack with a gearbox called "C" type? or is it a program u have to use to use to adjust the gearbox?
Offline sotu
Re: 50 Euro robot
« Reply #13 on: April 12, 2007, 01:14:19 PM »
I just found this picture showing that the left and right side of the stick is different colors (Green and Red) And i would then assume it was 2 seperate sticks, each driving by 1 motor each. If not its colored each half stick in different colors!
Offline Hal9000
Re: 50 Euro robot
« Reply #14 on: April 12, 2007, 01:50:13 PM »
Are you actually serous?
Man, it took you this long to realise that?
I told you that ages ago. And I didn't even need to. Maybe you should actually read people's responses before posting all these needless ones.
Again, i'm sorry I have to say, but this is going a bit too far for my liking!
Offline sotu
Re: 50 Euro robot
« Reply #15 on: April 13, 2007, 07:23:30 AM »
If u look closely on the picture it looks like the same stick. Anyway if u think i got so many foolish questions u dont have to answar me. Remember im askin the whole forum not just u. And about the reading posts, if many people start telling different things i want an assurance that what ure telling me is right!! >:(
Offline ed1380
Re: 50 Euro robot
« Reply #16 on: April 13, 2007, 02:15:30 PM »
sotu
both you and breemen are from the netherlands . I'm sure he'd be glad to help you.
If anything you could build the $50euro bot.
Offline Hal9000
Re: 50 Euro robot
« Reply #17 on: April 13, 2007, 03:49:53 PM »
Big style. Good luck. I hope i've helped you.
« Last Edit: April 13, 2007, 03:53:10 PM by Hal9000 »
Offline sotu
Re: 50 Euro robot
« Reply #18 on: April 14, 2007, 01:04:37 AM »
sotu
Im from Norway  :P
Re: 50 Euro robot
« Reply #19 on: April 14, 2007, 01:11:24 AM »
sotu ... is it now clear to you what the Tamiya gearbox gives you? Can you use it for your project?
Albert
---http://www.personalrobotics.nl
Offline Hal9000
Re: 50 Euro robot
« Reply #20 on: April 14, 2007, 02:19:07 AM »
Albert
Oh wow, that is one cool bot!
Offline sotu
Re: 50 Euro robot
« Reply #21 on: April 14, 2007, 04:11:19 AM »
Albert
Yeah i can use it for my project. But im a little confused if i have to use a computer software to send information to the circuit card which will be sent to the gearbox. But after getting responds from people i now see that the metal stick on the gearbox is 2 seperate sticks each controlled be 1 motor each. So the gearbox can turn!
Re: 50 Euro robot
« Reply #22 on: April 14, 2007, 04:21:22 AM »
But what do you want?
1. A gearbox that can turn
2. A gearbox that cannot turn
Offline ed1380
Re: 50 Euro robot
« Reply #23 on: April 14, 2007, 05:26:09 AM »
Sorry sotu. both start with N and are in Europe
Offline sotu
Re: 50 Euro robot
« Reply #24 on: April 14, 2007, 10:10:13 AM »
I want it to be able to turn.
Re: 50 Euro robot
« Reply #25 on: April 14, 2007, 10:14:41 AM »
ok, then Tamiya 70097 is fine for you! :)
