Author Topic: I need some suggestions.  (Read 1335 times)
Offline galannthegreatTopic starter
« on: May 28, 2009, 02:03:16 PM »
I need some help in finding a servo that can rotate 360 degrees. Does Hitec or Futaba have any servos that can accomplish this? And I am wanting to find it in my hobby shop, so a specific type would be of great help.
I don't want to have to buy them online, because I am making a trip up to the hobby shop to get some servos for general applications and I thought that it would be a good idea to get this one aswell.
Thanks, Kurt. :)
Kurt
Re: I need some suggestions.
« Reply #1 on: May 28, 2009, 03:12:27 PM »
Rotate 360 degrees or a continuous rotation servo?
If you want a continuous rotation servo the LHS probably won't have them, but one option is you can ask them to order it for you and in a week or so you can buy it from them when it arrives.
« Reply #2 on: May 28, 2009, 03:53:00 PM »
I guess that's a good idea, and the reason for the 360 degree stop is because I have a rotating platform, and if it kept rotating to get to the next "closest" position, it would create an issue. So now that I think about it... If you have a general suggestion (internet or not), of a place in which I could find one, that would be awesome.
Thanks Razor Concepts for giving a clarification on what I needed.  :)
Kurt
« Reply #3 on: May 29, 2009, 02:28:33 AM »
have you considered using an electrical stop?
eg something that makes contact to tell the mcu that is has reached 360 degrees rotation?
« Reply #4 on: May 29, 2009, 09:05:59 PM »
That has played out in my mind a bit but if I can find a servo with that spec in would be awesome.
Kurt
« Reply #5 on: May 29, 2009, 09:09:13 PM »
yep, it would probably be more expensive, yes?
« Reply #6 on: May 29, 2009, 09:11:24 PM »
Yes, but for this one servo I don't mind spending abit more, and if I can get 2 my buddy can replicate my project.  :)
Kurt
« Reply #7 on: May 29, 2009, 09:18:16 PM »
now that's always good isn't it
« Reply #8 on: May 29, 2009, 10:33:11 PM »
Yes it is, and hopefully the project will turn out.
Kurt
Offline robologist
« Reply #9 on: June 11, 2009, 03:24:47 PM »
Use 2 servos, one horn hooked to the other, one servo upside down. Bottom servo does 0-180, top does the remaining 180 to 360.
Or get a sail winch servo, does 3.5 x 360 http://www.servocity.com/html/hs-785hb_3_5_rotations.html
Or get a 360 rotation gearbox ; http://www.servocity.com/html/spg425a-360_360o_rotation.html
Offline sonictj
  • Helpful? 11
« Reply #10 on: June 11, 2009, 07:06:42 PM »
Use a stepper motor.  You can rotate any amount of degrees you want very accurately.  A stepper can also move faster.  The only disadvantages are the simplicity of driving the motor, power and size.  Depending on your project though a stepper may be a better choice.  If the load on the motor is small a stepper would likely be a better choice.
« Last Edit: June 11, 2009, 07:10:37 PM by sonictj »
Offline awally88
« Reply #11 on: June 11, 2009, 07:52:11 PM »
I doubt that you will find 360o servos in a general hobby shop, I'm not sure about how big this store is but I would doubt they would have anything but the usual 180o ones. I think you may have to go online for it.
If you want to modify a normal one to rotate 360o there is a tutorial here
Last post July 22, 2009, 05:46:18 PM
by Loriath
Last post August 13, 2011, 01:11:33 PM
by Webbot
Last post September 02, 2011, 03:12:11 PM
by georgeecollins
Last post July 22, 2012, 02:22:17 PM
