Don't ad-block us - support your favorite websites. We have safe, unobstrusive, robotics related ads that you actually want to see - see here for more.
no, but sometimes the bootloader has been reported to be slow?its good just to have a usb/serial programmer around as it helps if you don't have a bootloaded chip.
Axon had a problem with the slow bootloader, not the Roboduino. They use different USB chips. Roboduino is based on Arduino which does not have any slow problems.
Quote from: Ro-Bot-X on June 05, 2009, 06:02:01 AMAxon had a problem with the slow bootloader, not the Roboduino. They use different USB chips. Roboduino is based on Arduino which does not have any slow problems.Is that a fair comment? Surely Axon and Roboduino are just hardware designs - ie they are just mcus with header pins - the Roboduino is a $50 Robot board with a USB port just like the Axon is a 640 board with USB. Slow bootloaders must surely be associated with the bootloader software itself - ie nothing to do with hardware. If there is a fault then maybe its that the ATMega640 bootloader is less used than the ATMega168. I'm a fan of both boards - but this seems to un-fairly put down the Axon.
hey, If I had a spare 100 dollars I'd buy the axon.
lol, wouldn't we all!is there no way you can get any money for an axon? i believe there is a contest on later in the year...but the roboduino still gets the job done... and pretty well too!
Started by Adityav95 « 1 2 » Electronics
Started by Adityav95 Electronics
Started by Adityav95 Software
