Author Topic: community project: motor driver module.  (Read 1559 times)
Offline SmAsHTopic starter
« on: June 06, 2009, 11:02:05 PM »
i thought i may as well start a topic as everyone else has.
i have attached an image of my one sided L298 dual motor driver module.
please tell me if you can see any faults with the design as i will start etching relatively soon.
if you have any questions about the board feel free to ask.
Re: community project: motor driver module.
« Reply #1 on: June 07, 2009, 02:34:59 PM »
The less 90° and sharper bends you use, the better (better avoid them alltogether).
Don't make all the strange bends and turns where you can draw a straight line and use wider paths for the motor current where possible.
Your layout contains "blobs" of wider path in between, in places where it just looks odd.
No reason to use narrow tracks where you have room for more - just poses a risk of being etched through.
If you need to use jumpers, it's better to make them straight lines with pads.
If you post the schematic, I'll push it through Eagle to show you my points if you like.
« Reply #2 on: June 07, 2009, 03:46:36 PM »
i see your point soeren,
ill go through the design later and fix up any mistakes i made.
thanks!
Offline dellagd
« Reply #3 on: June 07, 2009, 04:51:50 PM »
I'm definitely not an expert, but I don't see any immediate problems.
If I helped, +1 helpful pls
I Won!
3rd place! I'm taking $100
