Author Topic: Connecting Comparator to Axon  (Read 1052 times)
Offline airman00Topic starter
« on: June 08, 2009, 06:03:06 AM »
I've set up a comparator circuit and it's all working, now I want to connect the output of the comparator to an Axon digital input pin. What is the maximum voltage a digital pin can handle?
Re: Connecting Comparator to Axon
« Reply #1 on: June 08, 2009, 11:52:58 AM »
This is a generic input protection useable for up to more than 30V
If your comparator is the kind with an open collector output it's even easier - just connect the pull up between the output and the controllers Vdd (that's what open collector outputs are specifically made for.
« Reply #2 on: June 09, 2009, 06:26:31 PM »
ATmega640 datasheet, silly :P
Without a protection circuit, it has to be less than the mcu voltage. Otherwise you'd get negative current. Although I'm sure it has some un-spec'd tolerance . . .
Last post November 18, 2008, 09:50:02 AM
by mbateman
Last post January 15, 2009, 09:15:48 AM
Last post January 10, 2009, 07:38:30 AM
by Tomas
Last post January 31, 2009, 01:47:09 PM
by robotcoder
