Author Topic: New Robot Build / 6 wheeled base (Pictures)  (Read 1764 times)
Offline guruTopic starter
  • Robotics, CNC, Electronics, Programming
« on: June 08, 2009, 08:45:34 PM »
Here are some pictures from Solidworks. Construction mostly from commonly available flat stock aluminum and some sheet metal aluminum. Motors are buehler 24v and can be found on ebay and around. Wheels are HPI 4456, but shown modeled without the complex tread pattern, of course. Green boxes are two 18.5v LiPo 8000mAh each. Should run for about 8 hours. The controller is an original XBOX! Haha! :) I had this xbox in my car and had made my own custom ATX-to-xbox cable with level converters already. I also did tests a few years ago and it ran about 1.5 amps at 18v input (27W) with the DVDROM (not spinning) and a laptop hard drive. I will not use the DVDROM and I will use a Compact Flash for HD. Xbox uses Xecuter3 mod chip and runs Linux. Xbox controllers are actually usb ports in a different plug format only. I took a pic of the xbox mainboard and texture mapped it on for show but the camera lens is warped so things dont line up perfectly, but the xbox model itself was fully digitized using micrometer measurements.
Not modeled are 6x H-bridge motor speed controllers. I will probably also place a FPGA eval board I have on hand via the usb port. The FPGA will give lots of programmable IO.
I will follow up with some real pictures as I start the construction soon. I will make the Solidworks or exported files available.
Colin
Re: New Robot Build / 6 wheeled base (Pictures)
« Reply #1 on: June 09, 2009, 03:10:29 AM »
hi there Colin,
you have a great looking robot there!
what sensors are you looking to employ for your robot?
« Reply #2 on: June 09, 2009, 12:00:35 PM »
I have 3 IR range sensors on hand that I will probably grab first and place on the front. I kind of like the Laser range finder too so I may move the 3 IRs to the bottom for detecting stairs, etc. I also want to mount a web cam on an RC servo gimbal on top. Initially, it will be a remote control robot via wifi. A web page will contain the webcam video and have some controls to move the bot. After that, I would like to make an iphone app that does the same thing, sweet! After that, I will mount a motion detector from a security system. This motion detector will simply trigger the robot to power up from sleep, track motion with the webcam, record to remote location and page my phone. Thus, I will have a simple security system. I could also add a very loud alarm perhaps.
Next, I want to go autonomous. My whole interest in robotics is not so much mechanical as it is about creating AI. Since I was a kid, programming in grade 3, I was interested in how everything works, electronics, mechanics, physics, but most especially the brain. I'm going to digress from your question, but when I was in grade 9 I learned how to hypnotize, mostly from closely watching the stage hypnotist Raveen. That only fueled my interest when I delved into the depth of my friends' minds. One in particular (much later in life), was most interesting, his mind was an enigma, ...highly suggestable, highly creative, an internal representation of the world much richer than most people, and yet, personality disorders bordering on multiple personalities and dilusion. For example, he was the only subject that talked about his conscious self in the third person. It explained a lot of peculiar behaviors in his life, but he did manage to "keep it together" generally. I hypnotized a lot of people, but his was a unique experience, I feel it also gave me some insight to how the brain worked. Probably, the nature of the brain will be revealed to us through the ones that don't work as opposed to the ones that do.
Colin
Last post July 26, 2008, 04:58:05 PM
Last post August 20, 2008, 06:26:22 PM
by steferfootballdude13
Last post March 28, 2009, 12:36:29 PM
by jamort
Last post July 06, 2011, 07:21:55 PM
by corrado33
