Author Topic: battery question  (Read 1705 times)
Offline antiTopic starter
battery question
« on: April 04, 2007, 12:03:10 PM »
 i have a 6 v nimh 2000mah battery, im trying to use an old battery charger to charge it but i need to know if it will work.  the output is 6v dc 250mA and im wondering if it will fry it, since i heard that 100ma is usually sufficient.  please help. ???
Offline dunk
Re: battery question
« Reply #1 on: April 04, 2007, 12:19:23 PM »
nope. i'm afraid that's not going to work very well.
<tacky_metaphor>think of voltage like water pressure. your battery is the same voltage as your charger so no current will flow.</tacky_metaphor>
as for current, generally 10% of the mAh rating in mA for around 12 hours is a good figure.
so you would want 200mA.
if your charger says "250mA" on the plate on the bottom of it then that will be the maximum current it can supply (with out blue smoke).
that doesn't mean it will supply that much.
try this thread: http://www.societyofrobots.com/robotforum/index.php?topic=319.0
there are a few other posts on this forum about charging batteries so try searching here. your questions have probably been answered allready.
Last post September 09, 2007, 09:21:30 AM
by HDL_CinC_Dragon
Last post December 19, 2007, 02:01:08 PM
Last post January 05, 2008, 10:28:44 AM
by HDL_CinC_Dragon
Last post August 11, 2011, 08:09:33 PM
by corrado33
