Author Topic: underwater switch  (Read 3656 times)
Offline karmaxTopic starter
underwater switch
« on: June 10, 2009, 03:02:29 PM »
hi.. actually i  am working on a underwater project .so i want a switch that is waterproof and can work in underwater also.i want to use it for killing the bot .i cant find switches.please help me
Offline Metal Slug 2
  • Helpful? 11
Re: underwater switch
« Reply #3 on: June 15, 2009, 11:06:45 PM »
thanks for help i have seen it earlier also.but i want underwater switches not waterproof switches.they will not work in undewater
« Reply #4 on: June 15, 2009, 11:10:38 PM »
a normal switch wrapped in some gladwrap?
what sort of water are we talking about? salt or normal?
  • Helpful? 11
« Reply #5 on: June 15, 2009, 11:26:45 PM »
hmm, unless im mistaken, anything that is "waterproof" can be used "underwater".  Of course, with your robot, the electronics must be contained in a water-tight container...the switch I linked to in my last post would work, if you took the leads of the switch and ran them through to the water-tight container and sealed the holes with some underwater rated silicone sealant.
Or maybe you have an underwater remote control type switch idea...
perhaps you could use a reed switch.  have the reed switch located inside the robot attached to one of the walls (also with a piece iron to hold the magnet on).  Then use any magnet to extenally turn on and off the robot.
« Last Edit: June 15, 2009, 11:28:26 PM by Metal Slug 2 »
« Reply #6 on: June 15, 2009, 11:33:18 PM »
actually i am working with 24v,50A switch .and i cant find that value reed switch or a normal waterproof switch.
« Reply #7 on: June 15, 2009, 11:42:59 PM »
[sarcasm]
thats not dangerous at all
[/sarcasm] what about using a transistor hooked up to a relay?
« Reply #8 on: June 15, 2009, 11:51:40 PM »
ya, that i can but i dont want to increase electronics because i have size constrain.so if u can tell me any switch that can work 24v,50A in underwater also that will be beneficial for us
Offline Trumpkin
« Reply #9 on: June 16, 2009, 09:32:53 AM »
[sarcasm]
[/sarcasm]
Actually it isn't that dangerous. It may be enough to give you a jolt but I don't think it could do you any serious harm (maybe under the right conditions). Anyways, I don't think you're going to find a reed switch rated for 50A, but you could have a reed switch turn on a relay.
Robots are awesome!
Last post February 25, 2006, 08:59:28 AM
Last post September 11, 2009, 06:08:27 PM
by SmAsH
Last post April 03, 2010, 11:04:31 PM
by coldwaterak
Last post June 10, 2010, 06:11:46 PM
by madsci1016
