Author Topic: two dc motors synchronous commanding  (Read 560 times)
Offline arixIITopic starter
« on: June 10, 2009, 04:40:55 PM »
In a post I made here:
http://www.societyofrobots.com/robotforum/index.php?topic=8180.0
I asked a question, about how I can command two motors using one line of code, but not two separate lines. I compared two coding style of ssc-32 motor controller, where you can command two dc motors in two separate lines like:
Serial.println("#0 P1400");
Serial.println("#1 P1600");
and also in ONE single line which is my intention as:
Serial.println("#0 P1400 #1 P1600");
the thing is that I am going to use PIC and I don't know how this is being implemented with a pic, and two dc motors connected to it with two standard H-Bridge. In that post I made, someone gave a good answer as:
To start/stop both motors at the same time, just change the bits of a byte that you transfer to a port they're hanging on, no big deal.
this is a correct answer, as I am not going to use any serial communication, but the PIC has PWM and is going to be connected directly to H-Bridges, hence setting bits to change the port is right in theory. But I don't know how this can be coded (I am a novice). Please if anyone knows how to implement this answer in programs, give me a code fragment example, showing how to "change the bits of a byte that you transfer to a port" for simultaneously commanding two motors.
Last post January 22, 2006, 02:33:50 AM
by monsta
Last post April 27, 2008, 01:43:51 PM
Last post August 08, 2008, 05:28:48 AM
by airman00
Last post June 10, 2009, 05:03:48 AM
by Ro-Bot-X
