Author Topic: Bluetooth Axon and vista  (Read 1430 times)
Offline KlingerTopic starter
« on: June 12, 2009, 09:28:07 AM »
I have a Axon mircoController and BlueSMiRF attached together with Uart0. I trying to talk with it with my vista computer. I can see the module and I attach to it but I cannot talk to it. I am using Hyper terminal private edition. I talking to the same com port number 5. But if I try and do anything it say "com5 unable to open please check setting". Then vista normal ask for a pin number to talk to the robot. I checked on the same baud rate.
Here is my coding just in case
 uartSetBaudRate(0, 38400);
char cByte= uart0GetByte();
   while(1)
   if(cByte =='1')
   backward();
thanks
I found the Password 1234now the green  'connected' Light is on
the Com5 error is not there. But I still cannot type anything in.
« Last Edit: June 12, 2009, 12:41:05 PM by Klinger »
Offline sonictj
  • Helpful? 11
Re: Bluetooth Axon and vista
« Reply #1 on: June 12, 2009, 01:44:38 PM »
Are you sure the bluetooth port is also com5?  On my computer I never get the same port for different connections.  go to device manager and clarify com5 is correct.  Also make sure that you are selecting none for flow control.
« Reply #2 on: June 12, 2009, 01:47:48 PM »
no I am still on com 5 which is the 'SPP' profile
The Light is now Green, But I still cannot communcation with the Robot.
Nothing come up on the terminal screen
« Last Edit: June 12, 2009, 02:38:57 PM by Klinger »
« Reply #3 on: June 14, 2009, 10:21:58 PM »
Strange that you are on com5, and it won't let me use any com less than 6 . . .
Try transmitting data instead. Do an rprintf("hello world"); and see what happens.
Also, your code should be this:
while(1)
   if(cByte =='1')
      backward();
« Reply #4 on: June 18, 2009, 02:14:53 PM »
I have fix the program so.
I put in the rprintf so but i just getting ASCII symbol on my screen and it is not listen to any commands that I type.
   while(1)
   cByte=uart0GetByte();
   rprintf("Hello World \n");
   if(cByte =='1')
      while(1)
      backward();
« Reply #5 on: June 18, 2009, 02:19:24 PM »
Your baud is wrong ;D
« Reply #6 on: June 18, 2009, 02:43:35 PM »
 I have tried all of them it just say the same thing in ASCII
« Reply #7 on: June 18, 2009, 08:45:10 PM »
Show us more code . . . like what is cbyte initiated as?
Last post July 27, 2008, 08:51:47 PM
Last post January 17, 2009, 05:56:16 PM
by Joe
Last post February 11, 2009, 10:53:15 PM
by Wizzard
Last post September 21, 2009, 10:10:44 AM
by jaime
