Author Topic: sound activated switch  (Read 6741 times)
Offline ert481Topic starter
  • yo young?
« on: June 16, 2009, 09:35:20 AM »
I need a very simple yet sensitive sound activated switch. either a schematic or link. i searched google and couldn't find a simple one.
thanks
young people can build robots to!!!
Offline Trumpkin
Re: sound activated switch
« Reply #1 on: June 16, 2009, 09:40:52 AM »
I did a quick google search and found this http://electroschematics.com/704/sound-activated-switch/
Robots are awesome!
Offline GearMotion
  • Helpful? 24
« Reply #2 on: June 16, 2009, 10:58:58 AM »
"Hoooooonnnneeeeyyyyyy! Turn the light on."
That has always been my simple sound activated switch.
 :P
Are you looking for any sound, or a specific tone?
  • yo young?
« Reply #3 on: June 16, 2009, 01:46:32 PM »
i need one for any sound...i dont know how you found that schematic but that should work unless theres any simpler.
  • yo young?
« Reply #4 on: June 16, 2009, 02:19:52 PM »
i also need a 2 second delay switch to shut something off.
thanks
« Reply #5 on: June 16, 2009, 02:54:51 PM »
use a microcontroller. all of this can be done using one. read up a bit.
as for the switch you could use a microphone with a set threshold in the code.
ie. when the sound gets to a certain level it does something.
  • yo young?
« Reply #6 on: June 16, 2009, 03:42:09 PM »
i dont wont to program anything....this is kinda a security system an i just want something basic.
« Reply #7 on: June 16, 2009, 04:05:07 PM »
then my friend, it will be a task... how does a tin can rigged up to a trip wire sound?
security systems ARE complicated if you want them to work well.
without a microcontroller it will be hard to do.
what do you want it to do when it "hears" something?
  • yo young?
« Reply #8 on: June 16, 2009, 04:46:58 PM »
no this is not going to be anything advanced. i just want a sound activated switch hooked up to an alarm so it turns on then build a 10 second delay before it shuts off. Or i was going to have it hooked up to my shadow activated alarm so i can go over to it and clap and have it turn off the circuit.
« Reply #9 on: June 17, 2009, 07:00:29 PM »
You can build a delay very simple with a 555, with half a 4093, or with a couple of transistors + glue.
To go with the first two, they could be trig'd from either an electret microphone capsule and a transistor, or with a piezo disc if you only want it to trigger by loud sounds like clapping your hands (or by tapping near the disc ).
What output do you need when triggered, before that and after the timed part??, something like  this: __|¨¨¨|__  ?
What supply voltage?
  • yo young?
« Reply #10 on: June 17, 2009, 08:40:41 PM »
im going to be sending five volts thrue it.
Offline swagatam
« Reply #11 on: April 07, 2010, 06:20:48 AM »
thanks
Learn how to build a simple sound activated alarm: http://www.brighthub.com/engineering/electrical/articles/68202.aspx ;D
« Reply #12 on: April 07, 2010, 09:13:34 AM »
10 months too late and it's even a very bad circuit with the base of T1 unprotected  ::)
Offline swagatam
« Reply #13 on: April 11, 2010, 10:23:30 PM »
Is this site a legit one?
 :ohttp://www.infotechse.com/affiliate/idevaffiliate.php?id=881
Last post January 26, 2009, 02:23:52 AM
Last post April 26, 2012, 09:13:56 PM
Last post July 17, 2012, 12:56:20 PM
Last post October 23, 2012, 01:29:16 PM
by Krash
