Author Topic: Need help, PLEASE!  (Read 2171 times)
Offline sotuTopic starter
  • ïBB - Eye Biped Bot
Need help, PLEASE!
« on: April 05, 2007, 06:37:42 AM »
Can anyone PLEASE explain me (Easy) not to advanced so i cant keep up how to wire a battery to a Motor, but with driving it with a remote? So the motor won't rotate when i wire the battery to it but when i press the button on the remote?!
How to build a biped bot:
Offline nanob0t
  • Trust Your Technolust
Re: Need help, PLEASE!
« Reply #1 on: April 05, 2007, 06:52:36 AM »
Some equipment you'll need is a motor controller of some kind.  You can use a microcontroller and hook it to an H-Bridge if it is DC.
By remote I'm taking it as being wireless in some way.  You will need a reciever for the remotes signals, which will be connected to the microcontroller.  If it is not wireless, then hook it straight up to the microcontroller.
I do believe it is possible to make just an electronic circuit, but I am unsure of what types of remotes and such you are using.  If the remote is wired, then you can take a look at something Knex puts out.  Wireless is going to be a good deal more difficult.
Offline ed1380
« Reply #2 on: April 05, 2007, 07:14:07 AM »
http://www.societyofrobots.com/robotforum/index.php?topic=713.0
by remote he means having a wire coming from the remote going to the vehicle
« Last Edit: April 05, 2007, 07:14:58 AM by ed1380 »
