Author Topic: trouble clearing a bit  (Read 1096 times)
Offline PtMartinsTopic starter
« on: June 16, 2009, 05:26:36 PM »
After solving my power issues on the axon  :) I have a programming question.
I use all the time the cbi and sbi functions to clear and set bits, and they seem to work.
But in this code:
void LeftWheellBackON(){
//sbi(PINC,1);
PORT_ON(PINC,1);
void LeftWheellBackOFF(){
cbi(PINC,PC1);
//PORT_OFF(PINC,1);
//FLIP_PORT(PINC, 1);
The sbi doesn't work.
I call the LeftWheellBackON() and my encoder is instructed to turn left motor ON (back direction). Then If I cal lLeftWheellBackOFF(), the motor doesn't stop. My program continues normally, but the pin 1 is high....
I tried the commented functions also... I switch to portC 7, but the same occurs...
The PWM works fine turning on and off, and i use it for front motion.
Any ideas ??
Offline chelmi
Re: trouble clearing a bit
« Reply #1 on: June 16, 2009, 09:00:56 PM »
it's probably not the problem, but sbi and cbi are deprecated.
http://www.gnu.org/savannah-checkouts/non-gnu/avr-libc/user-manual/group__avr__sfr.html
did you try
PORTC |= _BV(PC1) to turn it on
and
PORTC &= ~_BV(PC1) to turn it off ?
« Last Edit: June 18, 2009, 09:44:33 AM by chelmi »
« Reply #2 on: June 17, 2009, 04:13:38 PM »
The link you posted is down, but that was the problem !!! It's fine now !
Does that mean that I have to update my avrlib ?
Thanks for your help.
Offline chelmi
« Reply #3 on: June 18, 2009, 09:54:53 AM »
Your welcome !
I fixed the link, it should work now.
AFAIK avrlib is not maintained. I've heard of a project to revive it but I can't find it. You probably have the last version.
Last post January 13, 2008, 12:46:28 PM
Last post January 31, 2008, 02:24:27 PM
by SmAsH
Last post July 01, 2008, 10:30:58 PM
by silent069
Last post June 01, 2010, 11:14:53 AM
