2
Author Topic: Best CAD software  (Read 5295 times)
Offline macbookTopic starter
Best CAD software
« on: June 21, 2009, 12:18:04 AM »
Hey,
I want to know which is the best CAD software for designing and simulating robots. PLz help me.
Re: Best CAD software
« Reply #1 on: June 21, 2009, 01:03:02 AM »
im going to assume that you don't want to pay anything?
i and a fair few people on here use google sketchup and it works great.
if you do want to spend money check out: autodesk inventor and solidworks.
« Reply #2 on: June 21, 2009, 05:07:30 AM »
Ya, I wud love a free of cost CAD software.  ;D
Hmm, i have never used or seen google sketchup. Is simulation also possible in google sketchup?
« Reply #3 on: June 21, 2009, 06:00:08 AM »
ehh, i don't think so sorry :-\
im pretty sure you can get simulation in autodesk inventor though...
Offline Canabots
  • Helpful? 6
« Reply #4 on: June 21, 2009, 06:41:33 AM »
Actually, simulation is available for Google Sketch-Up. It's called Sketchy Physics. It's more like an add-on to Sketch-up, since when you install it, you can use it while designing.
There aren't many tutorials about it...but there was a forum thread about it a while back...
EDIT: Ah, here it is! http://www.societyofrobots.com/robotforum/index.php?topic=5979.0
« Last Edit: June 21, 2009, 06:45:57 AM by Canabots »
www.saltech.wordpress.com
« Reply #5 on: June 21, 2009, 11:32:10 AM »
From where can i download that sketchy physics? Its not there on torrentz. :(
Offline Canabots
  • Helpful? 6
« Reply #6 on: June 21, 2009, 11:39:42 AM »
« Reply #7 on: June 21, 2009, 03:41:11 PM »
 :o and here i was thinking there was no free simulation software that goes with cad!
« Reply #8 on: August 01, 2009, 12:05:59 PM »
Which is better for designing and simulation and which is easier to use? Solidworks or Autodesk inventor?
Offline wil.hamilton
  • Helpful? 6
  • rtfm
« Reply #9 on: August 01, 2009, 02:32:38 PM »
neither is very hard to use, i'd say solidworks is slightly better, but thats preference
I've used both, right now I use solidworks b/c i have to use it for school, I've never done any simulation though
Offline semismart
« Reply #10 on: August 06, 2009, 12:06:45 AM »
well ive used autocad for 3 years now in my high schools robotics team and it works great. and from what ive heard from other robotics teams, solid works is a good program too, although it is very unfamiliar to me. but ive tried nearly every free cad program that there is and was very unsatisfied with all of them. you'll find that the free programs dont have command entry and have far less tools, and they also dont have parts libraries. so if your only doing this to get a ruff idea of what your bots going to look like and how its going to be layed out then sketch up or my top pick, emachineshop.com's program will work just fine. but if your doing anything more than look into a program that cost at least a few hundred, and make sure that you try the trial first.
Offline Joker94
  • Helpful? 26
« Reply #11 on: August 06, 2009, 05:42:46 AM »
sketchup has command entry and part libries
  • Helpful? 6
  • rtfm
« Reply #12 on: August 06, 2009, 06:12:43 AM »
i've used sketchup some and found it to be rather good, i couldn;'t draft as fast in it as i could in autocad but that was because i hadn't learned the interface as well.
i now people who are fast drafting with Pro/E but i can't stand it.  it's all up to preference.  Sketchup has enough features that you would be able to do just about any robot design in it
i'm not sure however if it allows for parametric modelling which could be an issue, but, with all the plugins it has, it might be able to.
Offline Joker94
  • Helpful? 26
« Reply #13 on: August 06, 2009, 06:18:23 AM »
i use it and it takes some getting used to.
  • Helpful? 6
  • rtfm
« Reply #14 on: August 06, 2009, 06:21:09 AM »
any CAD software does, when i first started using solidworks all of my previous experience was in autocad and inventor, i'm still not used to solidworks though i am getting better (when i was using autocad i was using it everyday, i only use solidworks a couple days a month)
« Reply #15 on: August 06, 2009, 06:22:33 AM »
I found skektchup quite confusing. I am using inventor and I find it more user friendly than solidworks and sketchup.
Offline Joker94
  • Helpful? 26
« Reply #16 on: August 06, 2009, 04:45:33 PM »
i hope you should see a difference in inventor to sketchup, inventor is way better, just look at the price tag
hundred of dollars    =     free
Offline nagycnc
« Reply #17 on: August 06, 2009, 06:01:47 PM »
If you want free sw try Alibre Xpress. It's a good tool if you want to learn solid modeling basics. You can do very basic interference simulations but no motion.
Offline matt liao
« Reply #18 on: August 07, 2009, 12:30:44 AM »
So many 3d softwares are suitable for you, such as UG, PRO/E, Solidwork, CATIA, but they are not free, very expendsive, some companies may buy them.
Offline Joker94
  • Helpful? 26
« Reply #19 on: August 07, 2009, 02:27:25 AM »
is Alibre design express a free down load and if so can you provide a link, just to try it out. It would greatly appreciated
Offline nagycnc
« Reply #20 on: August 07, 2009, 11:40:20 AM »
Here is the link for the free version of Alibre.
https://www.alibre.com/Register/RequestInfo.aspx
It’s limited but functional (read the limitations). I’ve upgraded mine to the next version for about $500 but I recall even the free version supports STEP and IGES exports to CAM. If I had the money ($5000?) I’d use Solidworks but Alibre is sufficient for me.
Higher versions does support some motion simulations (it doesn’t do gears) I think it’s around $1000.
Offline sonictj
  • Helpful? 11
« Reply #21 on: August 07, 2009, 12:16:43 PM »
pro engineer wildfire is $250 for personal use.  Its not a bad package though I prefer solidworks.  $250 is the best price I found for cad software of this caliber.  Also if you are a student you can get if for $99 and you can still use it after you graduate.
Offline Joker94
  • Helpful? 26
« Reply #22 on: August 08, 2009, 04:33:14 AM »
thanks nagycnc ;D
  • Helpful? 6
  • rtfm
« Reply #23 on: August 08, 2009, 06:28:34 AM »
if you're a student you can get any of autodesks products for free:
http://students8.autodesk.com/
this includes autoCAD and inventor
Offline Joker94
  • Helpful? 26
« Reply #24 on: August 08, 2009, 07:46:47 AM »
it dose not work for me as my school has already been registed >:(
  • Helpful? 6
  • rtfm
« Reply #25 on: August 09, 2009, 07:43:03 AM »
what do you mean?  it should work aslong as you have a valid email address from your school, although i could be wrong, i registered over a year ago
you should be able to have multiple people from the same school register.
Offline Joker94
  • Helpful? 26
« Reply #26 on: August 10, 2009, 02:42:38 AM »
when i filled out the infomation page and clicked submit and it poped up and said "this e-mail has already been reistured"
  • Helpful? 6
  • rtfm
« Reply #27 on: August 10, 2009, 07:27:25 AM »
hmm, are you sure you got the email right?
if you did, you could always use the reset password feature and have it email you the password ;)
Offline Joker94
  • Helpful? 26
« Reply #28 on: August 10, 2009, 05:45:55 PM »
i'll check now :D
Offline Joker94
  • Helpful? 26
« Reply #29 on: August 10, 2009, 05:53:02 PM »
this is what it says when i checked again
"Your registration could not be processed because the email address used has already been registered."
