Author Topic: $50 Robot Circuit Problem  (Read 924 times)
Offline Smyt3rTopic starter
« on: June 22, 2009, 11:58:54 AM »
Hi all.
I am at the programming stage of my $50 robot and I'm using the more expensive programmer (avr isp mkII). I would like to set my servos to "0" so I can modify them BUT when I plug the programmer header onto the board the programmer led flashes orange, which according to the documentation indicates a wiring fault or something such.   :-\
I have thoroughly checked my board for errors many times, and I can find nothing wrong. However, there obviously IS something wrong! I have also checked with a multimeter and there is the right current throughout the circuit.
Also, do I have to have both battery packs (9v + 4.8v), servos and photoresistors plugged in for the circuit to work properly?   ???
This project has to be finished in a week's time.
I have attached some photos of my circuit. Please excuse my abysmal soldering!
And yes I know the LED's in a weird place but I blew the first one.
Thanks in advance! ;)
http://bayimg.com/CaBBgAaCH
http://bayimg.com/CabbIaACh
http://bayimg.com/cAbBlAach
http://bayimg.com/CABBpaacH
P.S The pictures are very bad quality, I took them on my phone, but I will try to upload some good quality ones within a few days.
Re: $50 Robot Circuit Problem
« Reply #1 on: June 22, 2009, 12:26:18 PM »
PROBLEM SOLVED... by my mother... How humiliating! I connected pin 5 of the header to GND on the microcontroller when it should have been on RESET. My programmer has lit up all green!  ;D ;D ;D
Offline Finnik
« Reply #2 on: June 22, 2009, 12:28:02 PM »
Check if you have the header wired up correctly, I think I see that you've not wired the one going to "Reset"
You might want to check this message to check the other connections.
Hope this helps.
   ---EDIT
Problem solved whilst I was writing my post...
Think outside the box... inside is to crowded.
  • Helpful? 107
« Reply #3 on: July 01, 2009, 06:23:03 PM »
Hope that Mum now has her own SoR account  ;)
Last post May 03, 2008, 05:34:57 PM
Last post May 25, 2008, 02:17:51 PM
by Jdog
Last post July 03, 2009, 04:36:15 PM
by Webbot
Last post July 25, 2010, 11:05:05 PM
by voyager2
