Author Topic: Piezo Buzzers  (Read 1799 times)
Offline silo_xtremeTopic starter
  • I really love robots, they keep me awake at night.
Piezo Buzzers
« on: June 26, 2009, 12:45:44 PM »
Hey All,
How's everyone?
My electrical engineer put a SMT-2240-T piezo buzzer behind a BC817 (transistor I think).  So,  I'm not sure if I need to generate a 4KHz singal to turn it on, or if I need to just set a pin high.,
I'm not having luck with either.
What's the typical code for an ATMEGA for this type of application?  We're using an ATXMEGA .
Mike
Offline Trumpkin
Re: Piezo Buzzers
« Reply #1 on: June 26, 2009, 02:38:57 PM »
Usually you would just have to switch the pin high.
Here is some code to switch PORTD 7 high:
PORTD |= (1<<7);Before you would do that though you would need to declare that pin as an output like this:
DDRD |= _BV(PD7);
« Last Edit: June 26, 2009, 02:41:14 PM by Trumpkin »
Robots are awesome!
Re: Piezo Buzzers
« Reply #2 on: June 26, 2009, 03:10:43 PM »
Hey Trumpkin,
That is what i orginally thougt, but here is what I found:
http://www.pui.com/audioProducts/MovieClips/TechNotes/Glossary.asp?articalID=1
Since my buzzer is actually on PORTC Pin 6 -also as  Pin 21 on an ATXMEGA128A1  my code is this:
// Make PC6 an output
    PORTC.DIR = (1 << 6);
// Set that output to high
   PORTC.OUT = (1 << 6);
and I also tried sending a 4Khz signal as well.
Offline Trumpkin
Re: Piezo Buzzers
« Reply #3 on: June 26, 2009, 04:00:47 PM »
Could you post the datasheet of the buzzer?
Robots are awesome!
Offline Trumpkin
Re: Piezo Buzzers
« Reply #5 on: June 26, 2009, 05:20:30 PM »
Try connecting a nine volt battery to the two terminals of the buzzer (directly).
Robots are awesome!
Re: Piezo Buzzers
« Reply #6 on: June 26, 2009, 05:34:42 PM »
Hmm ... kinda hard to do when it's SMT part on a PCB.  ;)
Re: Piezo Buzzers
« Reply #7 on: June 26, 2009, 07:03:44 PM »
find the traces and touch probes/wires?
Offline Trumpkin
Re: Piezo Buzzers
« Reply #8 on: June 26, 2009, 07:05:06 PM »
yep, that's what I meant.
Robots are awesome!
Re: Piezo Buzzers
« Reply #9 on: June 27, 2009, 06:46:50 AM »
Ok All,
Thanks for the help so far.  When I connect it to a 9V battery I hear something that is almost like static.
Definitely not the correct sound.
Does this imply I need to send in a 4KHZ signal - I'm a bit confused because that's a resonate frequency (output??)
Offline Trumpkin
Re: Piezo Buzzers
« Reply #10 on: June 27, 2009, 08:10:09 AM »
The sound of static implies that this is a piezo transducer and not a piezo buzzer. Read a bit about them here http://www.kpsec.freeuk.com/components/other.htm#piezo. So it looks like you need a square wave with a frequency of about 4khz, which is probably what you were doing before lol....
« Last Edit: June 27, 2009, 08:18:55 AM by Trumpkin »
Robots are awesome!
Re: Piezo Buzzers
« Reply #11 on: June 27, 2009, 08:24:25 AM »
LOL.  I'm working on it.
Re: Piezo Buzzers
« Reply #12 on: June 27, 2009, 08:32:32 AM »
I think that's the problem. my signal is probably no square.  :)
Offline chelmi
  • Helpful? 15
Re: Piezo Buzzers
« Reply #13 on: June 27, 2009, 08:55:36 AM »
You are right, it's listed as a piezo transducer on mouser: http://ca.mouser.com/Search/ProductDetail.aspx?qs=sGAEpiMZZMuNFJjvCI6tQgUWCBGptnRr%2f1ZaW3omx7A%3d
Re: Piezo Buzzers
« Reply #14 on: June 27, 2009, 11:02:37 AM »
Ok.  So logic check me please.
Wouldn't this cause a 4000 Hz square wave?
unsigned int cycles = 30;
unsigned int freq = 4000;
PORTC.DIR |= 1<<6; //make PC6 an output
long i;
while (cycles > 0) {
PORTC.OUT |= 1<<6; // buzzer pin high
for(i=0;i<freq;i++);
PORTC.OUT &= !(1<<6); // buzzer pin low
cycles--;
if yes, how would I control the duty cycle?
Offline chelmi
  • Helpful? 15
Re: Piezo Buzzers
« Reply #15 on: June 27, 2009, 11:36:17 AM »
long i;
cycles--;
I see several issues.
First, to drive the pin low, you need to use a binary not operator (~), not a logical not (!).
Try:
PORTC.OUT &= ~_BV(PC6)
Second, your delay loop is completely wrong ;)
You need to introduce a delay corresponding to the period and the duty cycle you want.
The period is 1/F, that's easy. A complete iteration (HIGH then LOW) must last 1/4000Hz = 250 microseconds.
The duty cycle of a square wave is 50% so you need to drive your pin HIGH for 250*0.5 = 125 microseconds and then drive your pin low for the same duration.
so basically your loop should look like
  unsigned int cycles = 20000;           //make noise for 20000 * 250 microseconds = 5 seconds
  PORTC.DIR |= _BV(PC6); //make PC6 an output
    PORTC.OUT |= _BV(PC6); // buzzer pin high
    //wait for 125 micro seconds
    PORTC.OUT &= ~_BV(PC6); // buzzer pin low
    cycles--;
The way you introduce delay is up to you. You can use:
- a busy loop (like you did): it depends on the frequency of your MCU.
- a timer: take a look at this page for more information about timers: http://members.shaw.ca/climber/avrtimers.html
Michel.
Re: Piezo Buzzers
« Reply #16 on: June 27, 2009, 02:15:20 PM »
hmm... what compiler are you using?   my compiler does not like the PC6 or _BV function.
Either way, when I just changed _BV( PC6) to (1<<6)
and used delay_us(125)  from WinAVR util\delay.h
I didn't get this working.   I'm still working on it and will report back.
Offline chelmi
  • Helpful? 15
Re: Piezo Buzzers
« Reply #17 on: June 27, 2009, 02:49:46 PM »
I'm using avr-gcc 4.3.2 and avr-libc 1.6.2
I dont know WinAVR, but I guess there is a initialization function. Did you call it?
Do you have access to an oscilloscope or a multimeter with frequency measure?
Last post December 06, 2007, 09:45:59 PM
by airman00
Last post June 08, 2008, 12:34:11 PM
Last post June 29, 2010, 09:22:25 PM
Last post March 24, 2011, 10:57:50 PM
