Society of Robots - Robot Forum
Robot Tutorials
FAQ
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
News:
Squirrels have fuzzy tails.
Home
Help
Search
Chat
Login
Register
Electronics
Electronics
$50 LED
Print
Author
Topic: $50 LED (Read 775 times)
icoms8
Full Member
Helpful? 0
$50 LED
on:
June 27, 2009, 04:07:20 PM »
when i try to put in the chip to the i/o socket the LED lights up like it is working. but when i try to program it, it says devices is missing. whats wrong?
Logged
SmAsH
Supreme Robot
Helpful? 75
SoR's Locale Electronics Nut.
Re: $50 LED
Reply #1 on:
June 27, 2009, 04:12:17 PM »
you may have a short somewhere. maybe go through your board and check, especially near the led pin.
Logged
icoms8
Full Member
Helpful? 0
Re: $50 LED
Reply #2 on:
June 27, 2009, 04:36:38 PM »
im look at it and i think that because i used the 4.8 battery method. when i put on the 9v battery i put the + wire on the + 5v regulater and then i got rid of the capciter lead going to the regulater. could that be it?
Logged
SmAsH
Supreme Robot
Helpful? 75
Re: $50 LED
Reply #3 on:
June 27, 2009, 04:40:45 PM »
it should have battery + going to regulator pin 1, then battery - going to pin 2 and pin 3 going to the mcu +v...
also have the middle pin of regulator to common gnd. thats the minimum you need. then you can add power bus...
Logged
Print
Electronics
Electronics
$50 LED
