Author Topic: Help me with Microcontrollers  (Read 2549 times)
Offline cyber0066Topic starter
« on: April 07, 2007, 02:43:46 PM »
I'm looking for a versatile microcontroller unit. Just some background on me, I'm pretty familiar with the mechanical things (I'm Mech Eng student) as well as software but I know NOTHING about electrical. I've already built a mini sumo bot at school but I didn't touch the electrical part at all. So now I'm trying to learn more about electrical.
For the mini sumo bot at school, we were already given a circuit board so all we had to take care of was the mechanical and software portion. The circuit board was custom made but I was wondering if I can buy ready made circuit boards that I can use for other robots I want to build. Don't know if this matters or not, but the IC  components were:
PIC18f4580 microcontroller x1
MAX3313 x1
MC33886 HSOP package x2
Can anybody tell me what these parts do?
Anyways, I'm looking for some suggestions on a whole circuit board unit that I can buy. Here's my criteria
1. I don't want it pre-programmed. I want to program it myself using C.
2. I'm planning to use the board for a few robots...first will be another mini sumo and maybe some other applications like a line follower or other simple robots. I'd prefer to have more I/Os if I want to make more complicated robots in the future.
3. Have some sort of H-bridge so I can drive motors from it.
4. Some output indicators. LEDs are fine.
5. Cost...under $150. The custom made one cost around $60 CDN and that suited our purpose already.
So I hope these aren't very rudimentary questions...I really don't know a lot about electrical.
« Last Edit: April 07, 2007, 02:45:57 PM by cyber0066 »
Offline ed1380
Re: Help me with Microcontrollers
« Reply #1 on: April 07, 2007, 03:07:16 PM »
http://www.kpsec.freeuk.com/study.htm
Heres a great site to get you started
My suggestion is that you go to www.digikey.com and use that to find the data sheets for the ic's you mentioned
Offline snow
« Reply #2 on: April 07, 2007, 03:51:12 PM »
I like http://www.datasheetarchive.com/ for datasheets.
Offline zamboniman60
« Reply #3 on: April 07, 2007, 03:52:02 PM »
I recommend you get a 12 v wall transformer, a breadboard, and some parts (resistors, capacitors, transistors) from your local gougingly expensive electronic parts store - then get a beginner's guide from the library and muck around for a few hours. It's much more useful than extremely math-heavy theory courses.
Offline ed1380
« Reply #4 on: April 07, 2007, 06:14:01 PM »
Offline Brandon121233
« Reply #5 on: April 08, 2007, 11:51:49 AM »
First of all, currently I am not aware of any microcontroller development board which has a good H Bridge motor driver built in. Your probably better off buying one like this separately http://www.hobbyengineering.com/H1918.html. Now on to the microcontroller, you mentioned under $150, so I have a couple of suggestions about where to get started: If you want an AVR based controller board I would suggest the Wiring Programming Platform http://www.sparkfun.com/commerce/product_info.php?products_id=744. The Pololu Orangutan Robot Controller http://www.pololu.com/products/pololu/0225/ seems to be a good choice as well. Another often used board is the MIT Handy Board http://www.handyboard.com/hardware/, it is based on the Motorola MC68HC11, but it is a bit more expensive. If you want a lower end board that still has many features I would suggest the Arduino board http://www.sparkfun.com/commerce/product_info.php?products_id=666, I just ordered the Arduino myself and I am anxious to find out how much it can do.
        —Thomas Edison
Last post April 06, 2008, 10:34:16 AM
by JesseWelling
Last post June 05, 2011, 05:11:44 PM
by waltr
Last post July 16, 2011, 08:03:35 PM
by joe61
Last post February 09, 2013, 02:33:47 PM
by ErikY
