Author Topic: Analog Distance Sensor/ what servo to use?  (Read 1058 times)
Offline JedTopic starter
« on: July 02, 2009, 03:21:18 AM »
if i want to put my sensor on a servo so it can track objects walls and people what servo should i use?,
and how to attach them?
Re: Analog Distance Sensor/ what servo to use?
« Reply #1 on: July 02, 2009, 03:51:40 AM »
most servos will do fine, even your $50 robot servos!
you will need something called a mounting bracket to attach a sharp ir or sonar.
« Reply #2 on: July 02, 2009, 03:58:44 AM »
wat speed do i nead?
Offline kpmcgurk
  • Robot Love?
« Reply #3 on: July 02, 2009, 04:53:14 AM »
really anything would work, since it is a reletivly easy task for a servo. as far as speeds and torque, you dont need to get that detailed. for mooving a sharp IR, all you really need is an HS-311 Hi-tech servo.
http://www.servocity.com/html/hs-311_standard.html
some people are just Born smart, but some people have to work for it, and those are the people who succeed.
http://www.proboticworld.com
« Reply #4 on: July 02, 2009, 05:07:04 AM »
if you have the $50 robot you can download admins stampy code for it..
the code is a sharp ir on a servo that tracks the left side of objects...
http://www.societyofrobots.com/robot_50_robot_sharpIR.shtml
Last post May 15, 2007, 04:40:35 AM
Last post June 07, 2007, 08:35:32 PM
by SomeSaba
Last post February 07, 2010, 05:54:23 PM
Last post January 28, 2013, 10:56:31 PM
by otai92
