Author Topic: looking for wireless transceiver under 50MHz  (Read 1722 times)
Offline AdminTopic starter
« on: July 02, 2009, 01:50:01 PM »
I'm looking for a wireless transceiver that must be under 50MHz and give at least 1kbps. Off-the-shelf is best, I don't want to make anything if I have a choice.
Anyone have experience converting a cheap 27MHz toy remote/receiver to transmit TTL data?
Re: looking for wireless transceiver under 50MHz
« Reply #1 on: July 02, 2009, 02:44:11 PM »
Nope, but I have used cheap walkie talkies for data transfer. Just output DTMF tones and decode them.
« Reply #2 on: July 02, 2009, 02:49:02 PM »
Old school! Got part #'s and schematic? Know the baud rate?
« Reply #3 on: July 02, 2009, 02:58:58 PM »
from my memory:
Used the Mitel 8870 DTMF encoder, bought it from BA Micro or something similar to that, maybe BA Electro?
Schematic was found in the datasheet, baud rate not sure. I guess it would be limited by the minimum tone length - I think I used the a tone length of 50mS , but I'm sure you can do shorter than that. The datasheet should have info about that. Also, only 16 tones available so you communicate sort of in "hex"
Offline sonictj
  • Helpful? 11
« Reply #4 on: July 02, 2009, 03:01:41 PM »
BG micro maybe? http://www.bgmicro.com/
« Reply #5 on: July 02, 2009, 03:03:12 PM »
Yep, good catch!
« Reply #6 on: July 02, 2009, 03:42:35 PM »
Any reason for not using just two tones for binary?
50ms for a single bit is waaaay slow. If I can't find any better solutions, I might read into the datasheet to see how fast it can really go . . .
Offline madchimp
« Reply #7 on: July 02, 2009, 05:01:35 PM »
I may be way off but wouldn't transmitting in "hex" 16 tones allow you to transmit 4 bits a shot rather than just a single bit as in binary? so the first tone would represent 0000 the second 0001 the third 0010 and so on?
Offline GearMotion
  • Helpful? 24
« Reply #8 on: July 02, 2009, 07:14:30 PM »
I've done things similar to that. The receiver detect chip will have a specification for valid signal detection. Detection of valid dual-tone was about 10ms. Since a dual-tone represents a nibble, then you get about 200 bytes in a second. Not fast enough for admin.
