Author Topic: Line Following Robot  (Read 1169 times)
Offline MangoBotTopic starter
« on: July 02, 2009, 10:03:09 PM »
hi guys, could you use a white (or any other color) LED to track that color line using a photoresistor. The programming would have it so that it goes away from the things that don't give as bright of readings. Would I need to have two LED/PHotoresistor setup? Any help or tips for a line following robot would help.
Offline Conscripted
  • Helpful? 10
Re: Line Following Robot
« Reply #1 on: July 02, 2009, 10:29:48 PM »
Hello,
Welcome to the society of robots. This should get you started in the right direction.
Conscripted
« Reply #2 on: July 03, 2009, 08:17:38 AM »
Thanks. I have not re-read that in a while. Do you think using two that try to avoid white so that the line we be inbetween the two sensors.
« Reply #3 on: July 03, 2009, 03:12:09 PM »
the general idea is that you have two sensors, one on either side of the line.
if one starts to see the line, the opposite side speeds up.
« Reply #4 on: July 03, 2009, 09:01:50 PM »
thanks, Ill post on this forum if i figure out how to make. Ill post videos and pics
