Author Topic: Reading Encoders  (Read 1288 times)
Offline arixroboticsTopic starter
Reading Encoders
« on: July 03, 2009, 08:28:36 PM »
Hi all,
I'm working on something that will need to read rotary quadrature encoders. I'm just wondering what are the usual interface people use to connect encoders to MCUs.
Here are the possible interfaces I could think of:
1. Use normal digital inputs, just keep reading the pin and count every encoder clicks. This is probably easiest, but will use up the whole MCU time. Then I'll probably need another MCU to do the processing.
2. Similar to 1, but using interrupts instead. So every encoder clicks will cause an interrupt on the MCU.
3. Use the built-in encoder module in dsPIC33F series. I've done this before, really easy since I don't need to worry about counting the clicks. But I'm trying to keep the cost to a minimum, and dsPICs cost a lot more compared to the others.
4. Use an encoder-reader IC. Does this thing even exists? I think I've seen it somewhere, but I can't really remember. Its an IC that is made specially for reading encoders.
Do you know any other ways? What technique have you used?
Re: Reading Encoders
« Reply #1 on: July 04, 2009, 01:16:30 AM »
you could use a smaller mcu that counts the clicks and outputs a corresponding analogue value to the master mcu?
Offline TrickyNekro
  • 1.6L Peugeot 307 tuner
« Reply #2 on: July 04, 2009, 01:49:18 AM »
It exists but I don't remember name....
Anyway, encoding is a matter of code.... You really need only one MCU for a quadrature encoder or maybe too....
How to do it....
Let's say you have a global clock that ticks it's own way on your system... It's 2am in the MCU 2am at the encoder (realtime system)...
In order to do parallel processing you need to set time as small small small fragments...
The MCU will read the ports and do all the math in that fragment.
You set that fragments with Timer interrupts, and let's say that our fragment is 1ms for example.
Take a look at the code below
' Timer interrupt is set to 1ms
Do
 IF a = 1 THEN
  a = 0
  CODE
  CODE
  CODE
  CODE
 ELSE
LOOP
TimerInterrupt:
 a = 1
RETURN
' Note that this code is executed in less time than the 1ms clock circle.
But if you want to count pulses then what???
Well..... in that case....
We need some more theory...
A signal from an encoder is typically a wave, to detect fronts of this wave you need the transition from low voltage to high
or reverse...To do that you simply need to read the port state. Once every tick of the interrupt.
Measure some ticks for some time then change the speed to the motors respectively.
So the code will look something like this
' Timer interrupt every 1ms
P0 = Pin(from one encoder)
Do
 IF a = 1 THEN
 a = 0
  IF b < 1000 THEN
   P1 = Pin(from encoder)
   IF P1 <> P0 THEN
    C = C + 1
   ELSE
   ENDIF
  ELSE
  b = 0   ' 1 second has passed
  ENDIF
  P0 = P1
  GOTO/GOSUB Motor_corrections
 ENDIF
LOOP
And... well I hope you get the rest of the concept :-P
Cheers!
« Reply #3 on: July 05, 2009, 01:52:51 AM »
Cheapest way (if you're afraid of any overhead on your primary controller) would be to use a PIC10Fxxxx and make a separate encoder that can be polled, whenever you have spare ticks, and then read its present count and direction and clear it.
But you have to have a very demanding application or some very sloppy coding to NOT have time for reading it directly on your primary controller.
Last post November 01, 2008, 09:24:01 AM
by Half Shell
Last post May 25, 2008, 03:15:20 PM
Last post September 01, 2009, 07:59:29 AM
Last post May 15, 2011, 04:04:12 AM
by Tommy
