Author Topic: $50 dollar capacitor soldering question  (Read 1267 times)
Offline mdmedlinTopic starter
« on: July 14, 2009, 08:45:48 AM »
I have a question.  I am soldering in the components to my $50 dollar board and when I get to the part of soldering the capacitor, the picture is not clear as to where I solder the capacitor.  It looks like on the picture that I solder the capacitor to the ground on one side, which makes sense, but it looks like the other leg of the cap is soldered to the two pins next to the ground but I think that the picture just has it soldered to the pin that is next to the leg.  Your help will be greatly appreciated thank you.
http://www.societyofrobots.com/step_by_step_robot_step3B.shtml
Do or do not, there is no try yes I changed my picture, it is of my daughter.
Offline Trumpkin
Re: $50 dollar capacitor soldering question
« Reply #1 on: July 14, 2009, 10:43:29 AM »
remember to look at the dot schematic and not just the pics! One leg of the capacitor should be soldered to ground and the other pin should be soldered to the input (left pin) of the voltage regulator.
Robots are awesome!
« Reply #2 on: July 14, 2009, 04:09:06 PM »
it doesn't matter too much where the capacitor is as long as the negative leg is to gnd and the positive leg is to the unregulated power bus.
to get it exactly right, the negative leg of the capacitor should be at 11D on the board and the positive leg should be at 11E. but as i said, anywhere inline with the battery+ and gnd is fine.
« Reply #3 on: July 15, 2009, 03:44:50 AM »
Yeah I went by the dot schematic so I soldered it where I believed the dot said it was supposed to go.  Thanks
Last post August 08, 2007, 01:49:15 PM
by HDL_CinC_Dragon
Last post August 22, 2008, 06:28:03 PM
Last post August 22, 2010, 07:50:14 PM
by ert481
Last post February 07, 2011, 01:38:17 AM
by Melcin Powell
