Author Topic: Atmega8 VS Atmega168 Vs Atmega328  (Read 10590 times)
Offline spizzakTopic starter
« on: July 16, 2009, 12:05:01 PM »
Could anyone outline the major advantages to the ICs. I've looked at datasheets and I know they are interchangeable in terms of pin layout. From what I gather the 168 has more memory and can run faster, and the 328 is another step up. Is there any other difference between them other than speed and memory?
« Last Edit: July 16, 2009, 12:25:59 PM by spizzak »
Offline GearMotion
  • Helpful? 24
Re: Atmega8 VS Atmega168
« Reply #1 on: July 16, 2009, 12:11:21 PM »
Only just from memory I believe that the timers are also different. And doesn't one have more pin interrupts?
You are on the right path looking at the data sheets. You need to compare each peripheral section.
ETA: The mega8 is not recommended for new designs. This tells me that the mega8A uses a different process and likely has different voltage specs. Same with the newer 168 (A? P?).
« Last Edit: July 16, 2009, 12:13:43 PM by GearMotion »
Re: Atmega8 VS Atmega168 Vs Atmega328
« Reply #2 on: July 16, 2009, 05:00:17 PM »
It actually goes mega48pa-88pa-168pa-328p
The mega8 is in a different "class" of atmegas, which is similar but not basically the same like the above.
Last post January 08, 2009, 12:13:20 AM
by pomprocker
Last post August 26, 2010, 01:28:34 PM
by euchrid
Last post June 22, 2011, 11:53:32 AM
by gshubham96
Last post November 20, 2011, 02:03:04 PM
by farnoise
