Author Topic: 50$ what is power bus?  (Read 739 times)
Offline Novice1Topic starter
« on: July 17, 2009, 06:10:25 PM »
What is the servo power bus? is it the same as the sensor power bus? (The picture is attached)
While you are at it, add in this purple wire. This wire will transfer the output 5V from your regulator to the middle row of the sensor power bus.
« Reply #1 on: July 17, 2009, 06:14:30 PM »
first of all, this a fairly old topic, please try not to bring up old topics. onto business...
you see the three header pins where you are supposed to plug your servos in?
the two outside pins are something called a power bus, because they are servos they get unregulated power.
your sensors normally need regulated power to give good reasons, hence regulated and unregulated buses.
from the chip outwards it goes, signal, +power, ground.
so the sensor and servo power buses are two different things, one gets it from the battery directly, the other gets it from the regulator which provides it with +5v regulated. hope that explained things better...
Last post February 07, 2008, 08:39:31 AM
Last post August 13, 2009, 10:47:09 AM
Last post March 07, 2010, 02:39:43 AM
by cyberfish
Last post May 03, 2010, 12:18:12 PM
