Author Topic: Getting rprintf to work with an LCD  (Read 943 times)
Offline KirkTopic starter
« on: July 20, 2009, 10:55:04 PM »
OK, so I know and love avrlib rprintf command (and the vt100 library).  I have used it in several projects over a UART.
Now I need to use a parallel LCD.
I got the LCD working using the avrlib LCD library, but not using rprintf.  How do I direct the rprintf data to the LCD?  What function do I put in rpintfinit?
Does anyone have sample code?
I doubt that \n and \t will work but that is OK.
Kirk
  • Helpful? 107
Re: Getting rprintf to work with an LCD
« Reply #1 on: July 21, 2009, 12:30:18 PM »
I think you need to write a function such as:
void LCD_printchar(char c){
  Then call the appropriate AVRlib methods to output the character
Then call
rprintfInit(&LCD_printchar);
to tell rprintf to call this routine for each byte being output
I dont have a parallel LCD - so thats the limit of my help!
« Reply #2 on: July 21, 2009, 05:02:37 PM »
Thanks!
When using AVRlib lcd.c and AVRlib rprintf.c the following links rprintf to the LCD
   rprintfInit(&lcdDataWrite);  // configure rprintf to use LCD for output
   rprintfInit(lcdDataWrite);  // this also works. I guess that I do not understand how this really works.
Alas \n does not work.
But the other nice formatting tools like rprintfNum work!
Thanks again for the help.
Kirk
Last post February 20, 2010, 11:41:25 PM
by Razor Concepts
Last post April 29, 2009, 04:49:19 AM
by Tomas
Last post September 02, 2009, 12:41:38 AM
by Webbot
Last post August 12, 2010, 07:55:54 AM
by Aberg098
