Author Topic: colour detecting sensors  (Read 1576 times)
Offline mohit sharmaTopic starter
« on: July 22, 2009, 07:32:43 AM »
Is there any kind of sensors which can be used for colour detection ? If there is so how they can be interfaced with microcontroller ?
Re: colour detecting sensors
« Reply #1 on: July 22, 2009, 07:57:36 AM »
when i think of color sensors, two spring to mind.
1. cameras, these are generally more for advanced users http://www.societyofrobots.com/programming_computer_vision_tutorial.shtml
2. the simple photoresistor setup, this setup is easy as pie...
you simply turn one color led on, read photoresistor, turn it off and repeat with a different color led.
check out http://www.societyofrobots.com/sensors_color.shtml
« Reply #2 on: July 26, 2009, 12:04:54 PM »
Yes, quite a few. Taos Inc makes some (http://www.taosinc.com/productfamily.aspx?sel=cs) and you can build from the ground up with a RGB LED.
Offline MangoBot
« Reply #4 on: July 26, 2009, 01:14:47 PM »
did you read the tutorial on color sensing, it is exactly what smash said, and the admin i think has a code written for following a red shirt(read FAQ) this is the tutorial: http://www.societyofrobots.com/sensors_color.shtml
« Reply #5 on: July 31, 2009, 12:46:35 AM »
thanks to all for replies it helped a lot
