Author Topic: need 100mW+ laser, under $200  (Read 1340 times)
Offline AdminTopic starter
« on: July 22, 2009, 08:55:35 AM »
I need a medium powered laser for a biochemistry experiment (energizing some molecules).
Basically I need from about 100mW to 200mW, although more is ok. Preferably under 400nm, around the UV spectrum, but not required.
Budget is under $300.
The best I can find is this:
http://www.mouser.com/Search/Refine.aspx?Keyword=551-NX7338BF-AA-AZ
(310NM, 110mW, $210)
Using multiple lasers I've been told is unacceptable by my coworker, but I don't quite believe him . . .
And another question . . . being a medium powered laser diode . . . anyone with experience on placing resistors in series with it? Can I treat it like a normal diode? Being $200+, I'd rather not burn it out ;D
I'm assuming a 10% efficiency, meaning probably 1 or 2 watts going through it, so I'd need a beefy resistor for sure . . . mmmmmm beef!
Re: need 100mW+ laser, under $200
« Reply #1 on: July 22, 2009, 09:02:35 AM »
Some blu-ray lasers are high power. Might find one surplus
http://www.lasersurplusparts.com/index.php?main_page=product_info&cPath=1&products_id=46
Offline spizzak
« Reply #2 on: July 22, 2009, 12:27:12 PM »
http://www.dealextreme.com/products.dx/category.911
This site has lasers really cheap.. typically the shorter wavelength, such as what you specified is really expensive but the green ones ~530nm are cheap. Not sure if they meet your needs, but worth a look. Also I think they have free shipping :)
« Last Edit: July 22, 2009, 12:30:27 PM by spizzak »
« Reply #3 on: July 22, 2009, 01:13:51 PM »
awesome! thanks both of you guys! :)
« Reply #4 on: July 22, 2009, 01:34:44 PM »
I think I got excited too early . . . apparently I can't import them to the US . . .
Important FDA Warning for all >5mW Lasers: FDA advices all customers that these lasers may be purchased only if you are NOT a citizen of the United States and you are NOT currently living in the United States.
« Reply #5 on: July 22, 2009, 01:44:46 PM »
Ok even more bad news . . . spoke with my coworker, and he now says it needs to be closer to 360nm +/- 15nm. The blueray stuff is too long of a wavelength. I guess the little molecules absorb only certain wavelengths . . . I'm not a biochemist!
He was going to order the above stuff anyway to try out considering the price, but it wouldn't let him.
I think the foreign stuff is cheaper as its not certified or tested for safety like in the US . . . doh!
Offline awally88
« Reply #6 on: July 22, 2009, 07:03:39 PM »
Nitrogen lasers can get close to this frequency I believe, according to wiki they are ~337nm for standard ones but I saw other ones mentioned on the net which should be closer to what you want. I'm not sure if you are going to be able to get this for <$300.
Offline RICEKING212
« Reply #7 on: July 22, 2009, 08:37:57 PM »
At rayfoss.com there are 100mw green lasers for around $75~. I was thinking that when I get better at robotics, I would mount one of these suckers on top of a robot and shoot ballons!
After looking at where rayfoss is located, I have found that they are from China and I doubt you'll be able to pass the laser through customs like what you said. :(
« Last Edit: July 22, 2009, 08:41:46 PM by RICEKING212 »
Offline awally88
« Reply #8 on: July 23, 2009, 08:21:23 AM »
Green lasers have a wavelength of 532 nm, read Admin's last post ;)
However that does look like a good laser shop for myself!
Offline andd64
« Reply #9 on: August 05, 2009, 06:52:28 PM »
Hey, this is the place i buy my lasers from.  I checked for your specs but they're crazy expensive.  Maybe you can find something else, but definitely check out this site:
http://www.aixiz.com/shop/index.php?cPath=1
Offline mdmedlin
« Reply #10 on: August 06, 2009, 01:59:56 AM »
I found this web site, I am not sure if this is what you are looking for because they want an e-mail request for product.  I have an uv flashlight that I got from grainger but it is uv led so I am sure that is not what you are looking for but here is the link: http://www.crystalaser.com/home.htm
Do or do not, there is no try yes I changed my picture, it is of my daughter.
Last post November 15, 2007, 11:34:08 AM
by Trumpkin
Last post December 11, 2007, 08:58:00 AM
by sdk32285
Last post January 07, 2008, 06:00:43 PM
by Rebelgium
Last post February 04, 2009, 01:21:52 PM
by amadcow
