Author Topic: Sharp IR range finders  (Read 871 times)
Offline shukiTopic starter
« on: July 22, 2009, 02:56:56 PM »
Hi everyone,
I'm a newbie to robotics atm... after studying everything behind circuitry, mechanics, and programming for a while I decided to build a robot.
My first robot is gonna be a simple rover that uses ir sensor's to avoid obstacles.
After looking at the different spec sheets for the different ir sensors, I couldn't decide wether to get the 1 inch - 12 inch sensor or the 4 inch - 30 inch sensor.
either : http://www.acroname.com/robotics/parts/R146-GP2D120.html
or :http://www.acroname.com/robotics/parts/R48-IR12.html
If I go with the gdp12 (longer range), can I program the robot to only react to obstacles located a certain distance from the robot?
Any help would be great :D
Thanks!
Offline pomprocker
  • Helpful? 16
Re: Sharp IR range finders
« Reply #1 on: July 22, 2009, 04:00:53 PM »
What you do is get the 4inch to 30 inch sensor, and you mount it 4 inches back on your robot ;)
« Reply #2 on: July 22, 2009, 04:12:44 PM »
yup, you can also have this first set when you start up your robot...
« Reply #3 on: July 22, 2009, 04:39:56 PM »
sweet, thanks for the ideas!
Last post March 25, 2007, 04:26:36 PM
by santiagoe
Last post November 12, 2008, 02:37:47 PM
by Builder1
Last post December 07, 2008, 09:37:33 PM
by Ro-Bot-X
Last post September 19, 2012, 02:16:56 PM
