Author Topic: LM393 dual comparator chip  (Read 1623 times)
Offline MangoBotTopic starter
« on: July 24, 2009, 09:15:54 AM »
Should i put this in a socket? Here's the link: http://www.goldmine-elec-products.com/prodinfo.asp?number=G32124
Offline chelmi
  • Helpful? 15
Re: LM393 dual comparator chip
« Reply #1 on: July 24, 2009, 09:42:30 AM »
I see two advantages to sockets:
1- prevents you from frying the chip when soldering it (if you're not very skilled)
2- easily change the chip if it burns.
So it's really up to you. If you are sure if your circuit (e.g. you prototyped it on a breadboard, ...), there is no reason for it to fry. And unless you're really bad at soldering, you should be able to solder this chip without frying it. I wouldn't use a socket, but again it's up to you.
Chelmi.
« Reply #2 on: July 24, 2009, 09:46:43 AM »
yeah, i will use a socket
