Author Topic: IC's  (Read 795 times)
Offline MangoBotTopic starter
IC's
« on: July 25, 2009, 12:14:29 PM »
would the LM393 dual comparator chip work with a SN754410 qaudruple half-h driver work together? chip: http://www.goldmine-elec-products.com/prodinfo.asp?number=G32124 and the motor driver: http://www.pololu.com/catalog/product/24
If they do work together what modifications should i have to this ( http://www.societyofrobots.com/member_tutorials/files/DC%20Motor%20Driver%201A.pdf ) so that i can hook it up to the comparator
« Last Edit: July 25, 2009, 12:22:36 PM by MangoBot »
Offline wil.hamilton
  • Helpful? 6
  • rtfm
Re: IC's
« Reply #1 on: July 25, 2009, 12:50:17 PM »
More information on what you're trying to do would be helpful.
If we know your end goal (what your robot is eventually going to do), it would help us tell you how to design a circuit.  In the mean time, try googling for comparator and motor driver, usually anything you try to do someone has done before and documented.
Re: IC's
« Reply #2 on: July 25, 2009, 01:38:57 PM »
im trying to use photoresistor to sense a line(a line follower) the comparator gives the comparison to the motor driver and it tells the motors to speed up or slow down
  • Helpful? 6
  • rtfm
Re: IC's
« Reply #3 on: July 25, 2009, 05:26:50 PM »
i dont think you need a comparator, you could just use and op amp, like i said, look at the BEAM herbie circuit, it does exactly what you want
Re: IC's
« Reply #4 on: July 25, 2009, 05:42:08 PM »
Well... a comparator is basically an op-amp.. not a huge difference  :)
Re: IC's
« Reply #5 on: July 25, 2009, 06:36:03 PM »
i have the circuit that i can use, i just need to know which pins of the comparator would go into the motor driver
Offline Joker94
  • Helpful? 26
Re: IC's
« Reply #6 on: July 25, 2009, 06:57:42 PM »
do a google search on your chip and you should be able to find a data sheet that has all of the pins labled, and then if you still cannot work it out post the data sheet or a link to the site that you got the datasheet from and so we can have a look.
Last post June 05, 2006, 04:39:14 PM
by polar bear6
Last post October 11, 2010, 05:23:42 PM
by madsci1016
