Author Topic: SER LCD question  (Read 1850 times)
Offline spizzakTopic starter
SER LCD question
« on: July 26, 2009, 05:16:46 PM »
Hey guys, I got this LCD to use with my atmega328 which I have clocked at 16Mhz however the LCD's datasheet says it can run at 8Mhz. Is that a problem? Do they both need to run at the same clock speed or should it be fine?
http://www.sparkfun.com/commerce/product_info.php?products_id=462
Re: SER LCD question
« Reply #1 on: July 26, 2009, 05:29:07 PM »
nope, as long as your microcontroller can communicate over uart at 9600bps.
The SerLCD backpack takes care of all the HD44780 commands allowing seamless integration with any micro that can communicate at 9600bps
Offline wil.hamilton
  • Helpful? 6
  • rtfm
« Reply #2 on: July 26, 2009, 08:13:52 PM »
which i'm fairly sure the atmega328 can, so you should be fine.  I'd double check the datasheet for the atmega328 to make sure though.
