Author Topic: Axon costumer support  (Read 4271 times)
Re: Axon costumer support
« Reply #30 on: August 05, 2009, 06:49:05 PM »
Offline sonictj
  • Helpful? 11
« Reply #31 on: August 05, 2009, 06:53:49 PM »
meiralfasi how did you download the hex file?  did you right click and "save target as"?  what did you name the file?  could you send me the exact file you uploaded.  I can try uploading it to my board as a  test.
Offline meiralfasiTopic starter
« Reply #32 on: August 05, 2009, 07:04:01 PM »
« Last Edit: August 05, 2009, 07:11:12 PM by meiralfasi »
Offline sonictj
  • Helpful? 11
« Reply #33 on: August 05, 2009, 07:36:38 PM »
uh I just tried it and I don't think it worked for me either  ???.  I'll get back to yah.  Here is my code there is a lot of libraryies and such.  I apologize if its difficult to understand I haven't taken time to properly comment my code.
« Reply #34 on: August 05, 2009, 07:40:23 PM »
Thank you very much .
So after all their is a glitch in the matrix , i was going crazy.
Offline sonictj
  • Helpful? 11
« Reply #35 on: August 05, 2009, 07:51:56 PM »
Probably, I think your mcu is fine.  You should be able to program it with no trouble.  My advice is to get an ispmkii hardware programmer so you don't have to deal with the boot loader.  There is more risk of doing bad things though.  With a boot loader you don't have to worry about screwing up the fuse settings which can brick your board.
« Last Edit: August 05, 2009, 07:53:15 PM by sonictj »
« Reply #36 on: August 05, 2009, 08:07:20 PM »
Thanks for the advice , I'm surprised that nobody encounter this problem before.
Offline sonictj
  • Helpful? 11
« Reply #37 on: August 05, 2009, 08:42:30 PM »
I don't know for sure if it is a problem.  I don't have the "exact" axon hardware.  I tested the code on my hand soldered, homemade board, and simulated a button press with a short circuit of the axon's swich i/o pin.  What matters is that your board is functional because you were able to upload my hex file.  I already told Admin about the possible problem with the servo centering program, so he can test it if he wants.
Now go make robots! ;D
« Reply #38 on: August 06, 2009, 06:31:42 AM »
Ok I'll look into it soon . . .
« Reply #39 on: August 06, 2009, 06:51:44 AM »
 The first Robot I'm going to build is going to be a robot that will Torture my wife ,
and I'm going to call it androtorturewife...
Got The Joke ?
« Last Edit: August 07, 2009, 07:54:39 AM by meiralfasi »
« Reply #40 on: August 06, 2009, 09:28:33 AM »
Now this is the problem, can i trust the axon setup instructions, may be the instructions are wrong,
 is anybody going to test the setup instraction ?
« Last Edit: August 06, 2009, 09:32:38 AM by meiralfasi »
« Reply #41 on: August 06, 2009, 09:38:17 AM »
The first Robot i'm going to build is going to be a robot that will torcher my wife ,
and i'm going to call it androtorcherwife...
Did you just say you were going to torch your wife? ???
And on the internet?
Hundreds of people own an Axon, and I've been selling them for over a year now. :P
« Reply #42 on: August 06, 2009, 09:52:18 AM »
http://www.societyofrobots.com/axon/axon_function_list.shtml
I uploaded and tested the six premed hax programs .
« Reply #43 on: August 06, 2009, 10:32:43 AM »
Well i can't explain why this pre made hax programs are not warking ,the just cause me to believe that the MCU is defective.
« Last Edit: August 06, 2009, 03:34:47 PM by meiralfasi »
Offline sonictj
  • Helpful? 11
« Reply #44 on: August 06, 2009, 10:44:31 AM »
Just because you couldn't get the test programs to work doesn't mean everything is screwed up!  Like Admin said he's had huge sales of the Axon and there hasn't been too many problems.  The fact is your board is functional.  Your going to find with any microcontroller product that at some point you will be scratching your head wondering what the #$*& is going on.  Robotics is like that.  Its so easy to mess something up completely trivial, and end up stumped for hours or days.  This is why Admin has made so many tutorials and FAQs to lower the learning curve.
get some help.
« Reply #45 on: August 06, 2009, 10:50:06 AM »
Then you for your help.
About my wife, I just wanted to input sum humor in to our conversation but I guess when you program alot you lose your seance of humor .
You need Help....
« Last Edit: August 06, 2009, 11:12:34 AM by meiralfasi »
« Reply #46 on: August 06, 2009, 11:22:13 AM »
To administrator . Instead of blaming me for doing something wrong why don't you backup your product , admit that there was something wrong with your
programing  and correct the problem.
Offline sonictj
  • Helpful? 11
« Reply #47 on: August 06, 2009, 11:36:16 AM »
You are under the incorrect assumption that because you and I could not get the centering program to work, that there must be a problem.  As I said before I do not have an Axon, and therefore any test I preform on my board does not mean it won't work on the axon.  Admin said he will look into the problem already.
quote from Admin
quote from meiralfasi
You have to give him time to look into the problem.  He isn't even online right now.
« Reply #48 on: August 06, 2009, 12:02:03 PM »
To administration .
 About that joke i meant to write torture my wife, as if to annoy hare. I misspelled it but you ware not smart enough to catch that
just like the axon programing...
« Last Edit: August 06, 2009, 12:37:03 PM by meiralfasi »
Offline wil.hamilton
  • Helpful? 6
  • rtfm
« Reply #49 on: August 06, 2009, 01:43:14 PM »
@ merialfast:
have you tried to write your own program (something simple to just turn an LED on)?
what environment and method are you using to program your axon?
could you post the output from when you try to program the axon (like whatever errors it gives)?
@everyone else:
could it be a makefile issue?
if the makefile is configured incorrectly (even the folder setup) it could cause programming errors
it might not even be uploading properly, it sounds like that could be the issue here
Offline sonictj
  • Helpful? 11
« Reply #50 on: August 06, 2009, 02:49:13 PM »
@ wil.hamilton
merialfast hasn't been uploading programs he's made, just hex files he downloaded.  There are no makefiles involved because nothing is being compiled.
« Reply #51 on: August 06, 2009, 03:10:04 PM »
That is right, Thank you .
« Reply #52 on: August 06, 2009, 04:08:43 PM »
This my point .
http://www.societyofrobots.com/axon/axon_FAQ.shtml
   Axon FAQ
I am a very weak programmer, is that a problem?
No, it is not! All the complicated programming has already been done for you. Almost any feature can be used by calling simple one-line functions, of which is listed in the Axon function list.
I have a little knowledge in programing  I wanted to use first the pre made programs and then I got into problem with The programs.
If you wrote instruction and programs in your website to be followed we expect those programs to work.
« Last Edit: August 06, 2009, 05:42:57 PM by meiralfasi »
« Reply #53 on: August 06, 2009, 07:22:01 PM »
Ok I tested it and it turns out it was a bad file. Not sure when I broke it . . .
Anyway, I fixed it and uploaded it.
No need to admin-bash, if my product has flaws, I lose sales! :P
« Reply #54 on: August 06, 2009, 08:01:58 PM »
Supreme Robot .
My apology, That was not my intention.
by far this is the best product out there , i guess this is part of the hobby , after all this is an open source format.
My advice to you is this , turn your knowledge off for 30 minuets pretend that you are newbie and go step by step the why you instructed in
axon website and see the results, try to compile a program build it and uploaded to Axon MCU.
Do not forget to program the emotion chip if A= ;D then B=$ .
Number five alive Stephanie.
And post the results.
Your prompt response is greatly appreciated .
« Last Edit: August 07, 2009, 05:54:18 PM by meiralfasi »
Offline Truckstop
  • I Void Warrenty's
« Reply #55 on: August 09, 2009, 07:33:06 PM »
its ok admin we still love you  ;D and im sure meiralfasi meant to thank you for the promt fixing of the program  :P
Truckstop
The Mongoose: Natures Assassin
The Hyena: Nature's A$$hole
And.....
The Lemming: Natures Retard
« Reply #56 on: August 10, 2009, 07:14:18 AM »
Yes ! we love ya .
Thank you for your help.
Last post September 01, 2008, 04:05:25 PM
Last post May 24, 2009, 07:14:28 PM
by jamort
Last post September 22, 2009, 04:16:00 PM
by jhaller
Last post May 29, 2012, 04:32:34 PM
by enforcer
