Author Topic: Program Compilation Error  (Read 1837 times)
Offline ukeshTopic starter
« on: August 06, 2009, 09:54:19 AM »
I'm writing a program to create an pulsing effect by using the led in axon mcu. The following, is the code in the control.c file.
void control(void)
ledpulse();
void ledpulse(void)
int i;
PWM_Init_timer1_LED(8);
PWM_timer1_On_LED();
while(1)
for(i=110;i<255;i++)
PWM_timer1_Set_LED(i);
delay_ms(10);//control pulse speed
for(i=255;i>110;i--)
I have not changed anything in the Axon.c file. I've changed the target name in the makefile. I get the following error.
Offline wil.hamilton
  • Helpful? 6
  • rtfm
Re: Program Compilation Error
« Reply #1 on: August 06, 2009, 01:50:42 PM »
it looks like you didn't include a header file for the PWM functions, its saying that those aren't defined anywhere
« Reply #2 on: August 07, 2009, 05:24:40 AM »
were can i find the header file for PWM functions? and where do i include the header file?
  • Helpful? 6
  • rtfm
« Reply #3 on: August 07, 2009, 06:41:42 PM »
i dont know what file the axon one is in, but to include it you would do something like
#include "pwm_file_name.h"
this should go at the top of your code
« Reply #4 on: August 08, 2009, 06:21:32 AM »
oh okie man, thanks.
can any users of axon guide me on finding the header file for pwm functions??
« Reply #5 on: August 09, 2009, 07:03:00 PM »
« Reply #6 on: August 10, 2009, 05:04:35 AM »
Its in timer640.c
http://www.societyofrobots.com/axon/axon_function_list.shtml#pwm
Do i need to add the header file timer640.h in the axon.c file ?
« Reply #7 on: August 10, 2009, 06:40:40 AM »
Its in timer640.c
It should already be there.
What code version are you using? This doesn't work on earlier code versions.
« Reply #8 on: August 10, 2009, 06:44:40 AM »
Its in timer640.c
no admin, i tried adding the header file timer640.h and still i get the same error. I'm using version 1.08.
« Reply #9 on: August 10, 2009, 06:49:26 AM »
ok I'll look into it tonight
« Reply #10 on: August 10, 2009, 07:25:14 PM »
ok so it appears it got broken when the PWM file was entirely rewritten . . .
Until I fix it, just add this code at the top of control.c, right after the variables are called, and it should work. It compiled fine for me, but I didn't test to see if it worked.
#ifndef PWM10
// mega128 PWM bits
#define PWM10 WGM10
#define PWM11 WGM11
#endif
//OC1B  pin B6 (attached to green LED)
void PWM_Init_timer1_LED(u08 bitRes)
// enable timer2 as 8,9,10bit PWM
if(bitRes == 9)
{ // 9bit mode
sbi(TCCR1A,PWM11);
cbi(TCCR1A,PWM10);
else if( bitRes == 10 )
{ // 10bit mode
sbi(TCCR1A,PWM11);
sbi(TCCR1A,PWM10);
else
{ // default 8bit mode
cbi(TCCR1A,PWM11);
sbi(TCCR1A,PWM10);
// clear output compare values
OCR1B = 0;
//on commands
void PWM_timer1_On_LED(void)
sbi(TCCR1A,COM1B1);
cbi(TCCR1A,COM1B0);
//off commands
void PWM_timer1_Off_LED(void)
cbi(TCCR1A,COM1B1);
cbi(TCCR1A,COM1B0);
void PWM_timer1_Set_LED(u16 pwmDuty)
{OCR1B = pwmDuty;}
« Reply #11 on: August 11, 2009, 08:51:35 AM »
thnx admin! It worked.  ;D
Can you work on this pwm error as soon as possible? If u can, it would be nice ;)
« Reply #12 on: August 11, 2009, 11:44:25 AM »
Well, since this quick hack fixes it, its now a low priority bug fix.
I'll make sure it works correctly with the next code version release.
Last post July 03, 2010, 02:00:34 AM
by mamintoosi
Last post September 21, 2011, 01:54:37 PM
by WaterPig Master
Last post June 17, 2010, 06:21:58 PM
by chelmi
Last post July 30, 2010, 01:10:03 PM
by sasap
