Author Topic: Simple Battery voltage monitor  (Read 2027 times)
Offline TruckstopTopic starter
  • I Void Warrenty's
« on: August 09, 2009, 06:11:17 AM »
So iv been reading allot of the older posts and liked the idea of a Robot cookbook full of Scraps of data. but have not found anywhere yet where anyone has actually started this. So here is my first contribution to the SoR site. A page for the future "cookbook"
This is a simple schematic For building a battery voltage reader device compatible with the basic stamp Microcomputers. it is very easy to build and not to hard to understand. it use's the RC time command. This circuit is good for a few things, one could be to activate a hunger mode and encourage a self recharge.
                 681 kohm        470 ohm
                 Vx ----/\/\/\---o-----/\/\/\----P0 to stamp
unknown                       |
voltage                    ===== 0.01 uF film
                                 Vss
(I like ASCII ART)
So here we go..
Suppose you want to monitor the voltage of a 12 or a 6 volt battery being used to power a project. There is no need to buy an analog to digital converter just for that. To measure the battery voltage, you can let it charge a capacitor through a resistor, and you can calculate the voltage from the charging time of the capacitor using the Stamp's RCtime command. Here is a circuit and some BS2 code. The following RC circuit is connected to BS2 pin P0:
Use stable components for best results, a 1% 681kohm resistor and a polystyrene or polycarbonate film capacitor. Here is BS2 program you can copy and paste..
{$STAMP BS2}
{PBASIC2.5}    'also works in 2.0
    rct var word             ' RCtime value
    Vx var word             ' voltage value calculated
                                    ' we want this to = applied voltage Vx
    Cn1 con 48576       ' first constant, see below
    Cn2 con 8               ' second constant, ditto
                                   ' circuit attached to P0
    low 0
    loop:
     RCtime 0,0,rct
     low 0
     Vx=Cn1 / rct + Cn2
     debug home,dec? rct,"Vx=",dec Vx/10,".",dec1 Vx
     pause 500
    goto loop
The program displays the raw RCtime value and the calculated voltage. You will see that as you increase the applied voltage, Vx, the time to charge up the capacitor up decreases.
Here is a table of actual values I collected: This shows the applied voltage measured by a voltmeter, and the raw RCtime value from the program.
    volts Vx RCtime, rct
    18       282
    17       300
    16       319
    15       342
    14       368
    13       401
    12       434
    11       479
    10       528
     9       592
     8       673
     7       780
     6       932
     5      1152
   4.5      1310
     4      1514
   3.5      1805
     3      2201
   2.5      2908 note--more fluctuation in rct at lower Vx
The RCtime values you find will be somewhat different, and the calculated voltages will be several tenths of a volt off from the true values. That is due to differences in component values from circuit to circuit. For best results you will have to find the appropriate values of the constants Cn1 and Cn2 for your particular circuit.
Enjoy
Truckstop
« Last Edit: August 09, 2009, 06:24:20 AM by Truckstop »
The Mongoose: Natures Assassin
The Hyena: Nature's A$$hole
And.....
The Lemming: Natures Retard
Last post January 12, 2009, 11:49:04 PM
by TrickyNekro
Last post February 15, 2009, 05:44:50 AM
Last post May 06, 2009, 12:34:36 AM
by SmAsH
Last post October 25, 2010, 06:38:39 PM
by z.s.tar.gz
