Author Topic: Photoresistor tutorial  (Read 1606 times)
Offline Blood-manTopic starter
« on: August 09, 2009, 09:50:06 AM »
I'm really confused by the photoresistor tutorial. I used analog multimeter and biggest photoresistors from Radioshack set. I get 6.703 KOhm. Is it OK? And can you explain me why I need to solder the end of photoresistor to the ground? I thought that it got to be analog output, because microcontroller not gonna read the ground, so it don't make any sense.
Offline sonictj
  • Helpful? 11
Re: Photoresistor tutorial
« Reply #1 on: August 09, 2009, 10:06:10 AM »
a photoresistor is a variable resistor.  It changes its value with different amounts of light.  You are simply creating a voltage divider circuit where you ADC channel connects between the two resistors.
gnd-------Photoresistor--- to ADC ----normal resitor---+5V
or
+5V-------Photoresistor--- to ADC ----normal resitor---gnd
the only difference is whether the voltage will increase or decrease which more light
Last post July 21, 2007, 06:26:00 AM
Last post June 27, 2007, 07:01:58 PM
by sdk32285
Last post October 27, 2007, 12:33:01 PM
by Trumpkin
Last post October 26, 2008, 09:39:44 AM
by drinu
