Author Topic: RF reciver  (Read 1004 times)
Offline Blood-manTopic starter
RF reciver
« on: August 10, 2009, 08:02:10 PM »
I found an RF receiver at Digikey http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=694-1005-ND for $9.82. Datasheets show 'Data rates up to 115kbps', so I guess it's fine. but it also shows "Receiver operating at the 902-928 MHz band." and "1.2MHz receive bandwidth". Would it be fine for the Atmega168 at my $50 robot??
« Last Edit: August 11, 2009, 04:52:23 AM by Blood-man »
Re: RF reciver
« Reply #1 on: August 11, 2009, 05:32:54 AM »
That's the throughput.
The carrier wave is within this band.
This is the bandwidth that the signal occupies (i.e. centre frequency +/- 600 kHz)
Probably, but without knowing how you wanna use it, it's really hard to say.
Re: RF reciver
« Reply #2 on: August 11, 2009, 08:11:51 AM »
I gonna create one way wireless connection with computer through radio transmitter and receiver. I will connect tx on the ATmega to the transmitter, it will transmit information to the receiver that connected to the TTL to USB adapter, and then  to the computer through the USB to the computer. I'm not sure that frequency of the receiver  would be able to receive data, because in the UART tutorial says that the frequency of the microcontroller got to be 8.00 MHz  ???
Re: RF reciver
« Reply #3 on: August 11, 2009, 03:32:00 PM »
The carrier wave frequency of the radio link (remember to get a matching transmitter as well) has nothing to do with the clock frequency of the controller - the carrier wave frequency is only relevant for the transmitter and the receiver.
I just skimmed the data sheet and discovered that the digikey page is not quite honest... The max. data rate is NOT 115 kbps. The max. data rate of the chip advertised on the page is 1'200 bps (= 1.2 kbps) - look at the "Product Ordering Information" on page 10 of the data sheet for verification should you need it.
Re: RF reciver
« Reply #4 on: August 11, 2009, 03:38:25 PM »
Many thanks!!!  ;D
