Author Topic: stand alone arduino chip?  (Read 1315 times)
Offline blackbeardTopic starter
« on: August 11, 2009, 06:47:02 AM »
i was wondering if it was possible to remove the microcontroler from an arduino and stick it on a standalone board made specificity for a robot i'm making i want it to be as low as possible and i'd like to avoid permanently sticking my arduino board onto it. i imagine all i would really need to do is add a resonator. what would be the circuit for that?
Next step: Give them vaginas
Offline Razor Concepts
  • Helpful? 53
Re: stand alone arduino chip?
« Reply #1 on: August 11, 2009, 08:52:14 AM »
It is just the AVR and a 16mhz crystal as you said. Checkout the Arduino schematics and see how the crystal is hooked up.
« Reply #2 on: August 11, 2009, 09:03:20 AM »
oh ok perfect! just one other thing though. i seem to recall that the chip is flashed with a special firmwear or something meaning i can't just go on digikey and order the same chip. is this true or did i miss something somewhere?
  • Helpful? 53
« Reply #3 on: August 11, 2009, 09:09:39 AM »
You can order the same chip (atmega168 or atmega328), but you will need an ISP programmer such as the AVR ISP MKII to flash the programs (and then you don't need the USB bootloader)
Offline wil.hamilton
  • Helpful? 6
  • rtfm
« Reply #4 on: August 11, 2009, 12:09:36 PM »
you can also buy the arduino chips pre-flashed with the boot loader from various sites
http://www.moderndevice.com/ offers 2 different versions of the chip with the bootloader programmed onto them
Last post November 10, 2007, 01:38:29 PM
by maverick monk
Last post May 15, 2008, 02:26:30 AM
by Private Reid
Last post January 01, 2009, 05:27:57 PM
by geek1
Last post January 14, 2011, 10:26:20 AM
by billhowl
