Author Topic: long signed int vs. int16_t  (Read 4058 times)
Offline AdminTopic starter
« on: August 14, 2009, 02:54:21 PM »
I'm following Webbots new tutorial:
http://www.societyofrobots.com/member_tutorials/node/341
and using his WebbotLib.
My code starts off like this:
#include "sys/axon.h"
#include "servoPWM.h"
#include "a2d.h"
//user includes
#include "kinematics.c" //SoR Biped Engine
// Define sensors
#define gyro_X ADC_NUMBER_TO_CHANNEL(0)
#define gyro_Y ADC_NUMBER_TO_CHANNEL(1)
//snip
And in kinematics.c, it starts off with this:
//initialize variables
int16_t r1L;
int16_t r2L;
int16_t r4L;
//snip
But that gives me this error:
../kinematics.c:24: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'r1L'
../kinematics.c:25: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'r2L'
../kinematics.c:26: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'r4L'
But if I change it to:
long signed int r1L;
long signed int r2L;
long signed int r4L;
then the error goes away . . .
This is happening to all my variables . . . Whats up?
In the manual, I see:
uint16_t counter;so something else is up . . .
Offline guncha
Re: long signed int vs. int16_t
« Reply #1 on: August 15, 2009, 11:12:13 AM »
Your compiler simply does not know what "int16_t" means, the reason being that either your code or Webbot's doesn't:
#include <stdint.h>
These (u)intXX_t datatypes are easier to understand and help porting code to different compilers (not that it matters when coding for AVR). Apart from that there is no difference on which one you use.
edit: removed some bad advice :)
« Last Edit: August 15, 2009, 11:16:44 AM by guncha »
« Reply #2 on: August 17, 2009, 09:56:13 AM »
Problem fixed. Use .h files!
An email from Webbot's phone, whose home internet connection isn't working . . .
Try renaming kinematics.c to kinematics.h and then including this h file rather than the c file.
Its not good practice to include another C file. The effects are probably undefined and in this case it 'forgets' all the includes from your main file and so 'int16_t' etc are no longer defined and hence the compile error. If its a 'h' file then all is ok
Nb this is a compiler issue/feature not my lib
Last post September 17, 2007, 06:01:02 PM
by ed1380
Last post January 14, 2009, 04:10:59 PM
by airman00
Last post February 03, 2009, 05:04:31 PM
Last post August 17, 2009, 03:29:30 PM
by Razor Concepts
