Author Topic: Abt DC motor  (Read 889 times)
Offline macbookTopic starter
Abt DC motor
« on: August 16, 2009, 03:19:07 AM »
I am working on a ladder climbing bot.
While the motor is off, I want it to remain stationary. Is it possible in DC motor? I want its axle to stay at its position when no current passes thru it. Which motor will serve this purpose best? DC motor (Geared or non-geared) or Stepper?
Re: Abt DC motor
« Reply #1 on: August 16, 2009, 03:24:23 AM »
with a dc motor you can brake it, just short power across the two terminals.
for ease of control i would go with a geared dc motor, but it all depends on your needs.
Offline benji
Re: Abt DC motor
« Reply #2 on: August 16, 2009, 05:43:42 AM »
Unfortunatly DC motors will drag big current when the load gets bigger and they start to heat, plus their velocity will decrease.
In order to not drag any current at all and save power while there is a backward force affecting the shaft the trick will be in the gearhead.
get a DC motor with a one-way gearhead, this will allow roation in the forward direction while suppressing any backward force.
good ol' BeNNy
Offline wil.hamilton
  • Helpful? 6
  • rtfm
Re: Abt DC motor
« Reply #3 on: August 16, 2009, 04:57:08 PM »
you could always use mechanical braking ;)
Re: Abt DC motor
« Reply #4 on: August 19, 2009, 05:33:15 AM »
Any kind of motor will do, as long as you use a worm gear.
Last post September 05, 2007, 07:12:24 AM
Last post September 02, 2008, 04:49:50 AM
Last post June 12, 2009, 01:02:45 PM
by Metal Slug 2
Last post June 14, 2009, 11:50:15 AM
by RoboChan
