Author Topic: Lassen GPS + 4 sensors - Axon - bluetooth?  (Read 1641 times)
Offline Ali1972Topic starter
« on: August 18, 2009, 03:37:16 PM »
Hi i'm new to this, it's starting to make sense but just want to check.. ???
1 Use the Axon powered by 12v cigarrette lighter to ;
2 retrieve GPS data from a lassen IQ chip
3 retrieve data from 3 flow sensors (pulse i think) - http://www.icenta.co.uk/pdfs/2100_turbine_flow_sensor-ic.pdf
4 retrieve data from 1 on /off switch
5 send it via bluetooth to PDA (HP iPAQ 214)
6 Write VB script to colate the data, save it etc..
Basically i would like to know if u think its possible. And if so, suggestions on putting it together and any hardware i need, just to make sure i buy the right stuff.
Thoughts
I'm guessing i need to make a board with a Lassen mating header on, antenna connections and data out connections.
Is there a problem with power spikes if it is plugged in and u start the engine?
Played with VB a bit so that should be the easier side to this......
Thanxs ;D
Last post July 27, 2008, 08:51:47 PM
Last post June 05, 2009, 01:37:53 PM
by jakx12
Last post June 18, 2009, 08:45:10 PM
Last post July 07, 2009, 07:50:20 PM
by kpmcgurk
