Author Topic: $50 robot microcontroller  (Read 708 times)
Offline violinkidTopic starter
« on: August 19, 2009, 04:08:43 PM »
I finished soldering everything, I dont exactly get how you are suppose to test the circuit. I have a multimeter with the settings of 20mA, 200mA, and 10A. It seems i have to plug the red line into the 10A hole and turn the switch to the setting of 20mA and it reads .3 I dont get what this means, can anyone help me? Also, is the LED suppose to light up when you turn on both the batteries?(I'm using the 4AA batterie holder +9v)
Offline sonictj
  • Helpful? 11
Re: $50 robot microcontroller
« Reply #1 on: August 19, 2009, 07:06:33 PM »
Testing the circuit is done with a continuity test, or resistance test.  You should measure no continuity or infinite resistance between power and ground.  The led is attached to a digital pin of the microcontroller so it will only light if you program it to do so.
Last post March 11, 2010, 07:37:39 PM
by Jaryd
Last post July 05, 2010, 09:35:06 AM
by Jdog
Last post April 08, 2012, 08:33:58 PM
by robotmaniac
Last post July 02, 2012, 07:09:30 AM
by Moyamo
