Author Topic: [Solved] Sabertooth blinking  (Read 2057 times)
Offline StephanieTopic starter
« on: August 19, 2009, 09:06:17 PM »
I have two signal cables connected to my Sabertooth 2x5. I use an Axon MCU.
The cables are very very bad (almost no solder, the solder is really bad, some parts are black because of the soldering iron).
When there's nothing connected to signal, there's nothing but the strong blue LED (everything is fine).
When I connect the signal cables to the Sabertooth, the LED's ok, but the motors start moving randomly, even if there's NOTHING on the other side of the cable (not even a turned-off Axon --- it's really nothing).
When I connect them to my turned-off Axon, it not only moves the motors randomly, but also the blue LED first glows dimly and then blinks strongly.
I intend to fix the cables tomorrow and tell here what happens. But, anyway, does anyone have a clue about what's happening?
PS: I don't know if this has something to do with it, but the robot chassis is made of aluminum and seems to be conducting electricity. I'm using spacers.
« Last Edit: August 21, 2009, 03:54:59 PM by Stephanie »
--- Stephanie
Offline sonictj
  • Helpful? 11
Re: Sabertooth blinking
« Reply #1 on: August 19, 2009, 09:36:10 PM »
1. Check and make sure all gnds are common.
2. What are the positions of the switches on the sabertooth.
3. What voltage are you putting into the sabertooth bat + and - terminals if your near 6V the sabertooth will act strangely.
4. How is the Axon connected to the sabertooth.
« Reply #2 on: August 20, 2009, 10:01:49 AM »
It's a 12V battery and 12V motors.
It's non-lithium R/C MCU mode.
It's connected through digital signal (s1 and s2).
I fixed the cables and now it's ok. But why did the motors move randomly whenever I put a cable there, even if they weren't connected to anything? Did the Sabertooth think it was receiving some signal?
--- Stephanie
Offline sonictj
  • Helpful? 11
« Reply #3 on: August 20, 2009, 10:22:19 AM »
It sounds like the sabertooth's ground line was "floating".  Meaning it was not grounded to anything, or there was poor contact.  This will cause erratic behavior.
« Reply #4 on: August 20, 2009, 10:41:18 AM »
Now the motors move strangely and the blue LED blinks again.
Well, there's M1A, M1B, M2A, M2B connected to two 12V DC motors.
Then there's S1 and S2 connected to the Axon's E3 and E4.
Then there's B+ and B- to a 12V NiMH battery.
Do I have to connect something to 0v and 5v? or they're just "free to use" outputs? How do I "unfloat"?
--- Stephanie
Offline chelmi
« Reply #5 on: August 20, 2009, 11:28:55 AM »
EDIT: removed stupid advice. I'll go hide somewhere :(
« Last Edit: August 20, 2009, 11:43:52 AM by chelmi »
Offline sonictj
  • Helpful? 11
« Reply #6 on: August 20, 2009, 11:31:39 AM »
No don't connect anything to the 5+ on the sabertooth thats a bec line providing 5V.  Just connect gnd from the axon to 0V.  The sabertooth provides its own 5V vcc for its logical circuitry.
« Last Edit: August 20, 2009, 11:33:04 AM by sonictj »
« Reply #7 on: August 20, 2009, 04:06:26 PM »
Thanks for the replies.
Don't worry, Chelmi  ;)
Are all the GNDs the same? Or is there a distinction between the grounds from the side rows and the grounds from the ADC row?
--- Stephanie
Offline sonictj
  • Helpful? 11
« Reply #8 on: August 20, 2009, 04:25:21 PM »
All grounds on the axon I believe are common.  You might as well get gnd from one of the power busses near the pwm lines going to the sabertooth.
removed stupid advice. I'll go hide somewhere Sad
Everything you said is generally right.  Don't feel bad everybody makes mistakes.  I hope you didn't think I was yelling.  I just used bold to make sure my comment wasn't glanced over.
« Last Edit: August 20, 2009, 04:29:36 PM by sonictj »
« Reply #9 on: August 20, 2009, 05:09:23 PM »
Alright.  :)
The UART has "T, R and G".
So for serial communication I connect:
- T to S1
- R to nothing
- 0v to G (my understanding is that the UART G pin is only to make connecting the triple Molex easier, it could be any other ground pin).
Is that correct?
--- Stephanie
  • Helpful? 107
« Reply #10 on: August 20, 2009, 05:49:43 PM »
You also need to check the Sabertooth mode of operation.
If its in simple mode (ie max of 1 Sabertooth board) then it allows you to configure baudrates etc.
But if you are using packetized mode (ie support mulitple Sabertooth boards in parallel) then you cannot config the baudrate. It uses the first character it is sent which it assumes to 0xAA to auto-config the baud rate. Sounds good - but I spent ages fixing my library so that a power on of the Axon didn't end up sending a 'glitch' character to the Sabertooth, which then made it set its baud rate incorrectly, which meant it just went AWOL.
Offline sonictj
  • Helpful? 11
« Reply #11 on: August 20, 2009, 06:28:36 PM »
yes, but when ever you connect any device to the axon you must have gnds common. so you will always need gnd.  This is why the header contains rx, tx,and gnd.
« Reply #12 on: August 21, 2009, 01:13:23 PM »
yeap, all common.
The G was a way to remind/help people to make sure grounds are common. ;D
« Reply #13 on: August 21, 2009, 03:54:45 PM »
It worked. Thanks everyone.  :)
--- Stephanie
Last post June 21, 2009, 06:46:40 PM
by ekcnepta
Last post August 15, 2009, 09:47:53 PM
by billhowl
Last post November 23, 2009, 03:06:46 PM
by z.s.tar.gz
Last post September 24, 2010, 07:38:05 AM
by waltr
