Author Topic: Bluetooth Tutorial - questions  (Read 2124 times)
Offline klimsTopic starter
« on: August 29, 2009, 01:17:15 AM »
Hey guys,
I recently bought a BlueSmirf for my Axon and am having some trouble setting it up.
I followed the video tutorial but I have a few questions that were not answered.
1. what software are you using on the PC end to connect to the BlueSmirf? Maybe Bluesoleil?
2. how does connecting through Hyperterminal make a connection to the BlueSmirf? does something need to be configured?
What I have tried is to connect to the BlueSmirf using Bluesoleil, then connect through Hyperterminal.
This lets me receive (not send) data from the Axon but it seems to be gibberish, albeit consistent gibberish
I have checked all the connections and wiring so its unlikely that is the cause of any of my issues.
The tutorial made it seem so easy! I must be overlooking something... any suggestions?
EDIT:
I have the BlueSmirf connected to UART0
I am powering the device off the 5v regulated bus on the Axon.
I do not have CTS and RTS jumpered
« Last Edit: August 29, 2009, 08:04:17 PM by klims »
Offline Truckstop
  • I Void Warrenty's
Re: Bluetooth Tutorial - questions
« Reply #1 on: August 29, 2009, 04:13:18 AM »
check the baud rate. no i don't have any experience with the blue smurf but its a good place to start.
Truckstop
The Mongoose: Natures Assassin
The Hyena: Nature's A$$hole
And.....
The Lemming: Natures Retard
Offline kpmcgurk
  • Robot Love?
« Reply #2 on: August 29, 2009, 06:47:38 AM »
I think this is what you are asking!!
You will need to make sure that either your computer has Bluetooth integrated or you have a Bluetooth usb key.
-How to connect to it: you connect to the Bluetooth on your robot the same way that you would with any Bluetooth device, such as your mouse.
-Once you have connected Via Bluetooth your "receive" should be given a com port on your computer, then when you connect to it through hyperterminal you choose that com port, and everything should work out just fine!!!!
REMEMBER THE ROBOT AND BLUESMIRF NEEDS TO BE POWERED DURING ALL OF THIS...
some people are just Born smart, but some people have to work for it, and those are the people who succeed.
http://www.proboticworld.com
« Reply #3 on: August 29, 2009, 08:55:57 AM »
Yeah this all makes sense. I have tried it all :/
I am definitely connecting correctly to the BlueSmirf using Bluesoleil (I checked a few tutorials)
No matter what baud rate I configure on the axon I get the same gibberish output. This makes me think something fishy is going on with the baud rates.
Any other suggestions guys?
« Last Edit: August 29, 2009, 08:06:38 PM by klims »
« Reply #4 on: August 30, 2009, 06:58:33 AM »
Turns out all I needed to to was enter the command mode on the BlueSmirf and bring down the baudrate to be 38400... For whatever reason it didn't work at factory preset 115200
thanks for the input guys
Offline Truckstop
  • I Void Warrenty's
« Reply #5 on: August 30, 2009, 04:36:33 PM »
Any time.  ;D
And.....
Offline Klinger
« Reply #6 on: October 10, 2009, 08:22:40 AM »
What command code did you enter?
« Reply #7 on: October 10, 2009, 11:03:59 PM »
Can't remember exactly. You'll need to read through the BlueSmirf user manual to find out. I think I remember something about $ sign though...
Offline radhoo
« Reply #8 on: October 11, 2009, 12:57:50 AM »
An alternative is using chinese UART Bluetooth modules you can get on ebay.
Setting up the components is easy:
http://www.pocketmagic.net/?p=869
I've tested the bluetooth connection using Hyperterminal, but once I start coding the robot brain it will be done directly from the smartphone.
EDIT: my baud rate is currently 9600bps.
Last post September 19, 2008, 08:28:09 AM
Last post June 01, 2009, 05:49:38 AM
by SmAsH
Last post October 12, 2009, 01:20:28 AM
by radhoo
Last post July 31, 2011, 03:15:24 PM
