Author Topic: Cheaper High Current Drivers  (Read 2290 times)
Offline airman00Topic starter
« on: August 29, 2009, 11:23:40 AM »
It just occurred to me that for high current situations ( like motors) it might be cheaper to use Solid State Relays.
http://futurlec.com/RelSS.shtml
For example a 40 amp motor controller - four relays - would be 17.90*4 = $71.60 . And since they are solid state and not mechanical you can pulse width them as much as you want.
To be clear: you could make a cheaper motor driver using MOSFETs , but in that case you would need additional components - MOSFET motor drivers, as well as a custom PCB. Using solid state relays allows you to make a motor controller without any custom boards and its much simpler. A MOSFET motor driver requires some know-how.
Offline Daanii
Re: Cheaper High Current Drivers
« Reply #1 on: August 29, 2009, 03:47:35 PM »
So you would use the four relays to make an H-bridge?  Clever idea, but is the switching frequency fast enough?
« Reply #2 on: August 29, 2009, 03:50:36 PM »
From the datasheet:
Max Turn on time = .5ms   Max Turn off time = .5ms
if you do your pulsing correctly you should be able to have proper speed control.
Offline Daanii
« Reply #3 on: August 29, 2009, 07:29:31 PM »
I notice these relays switch AC power.  Does pulse width modulation work to shape an AC power line to drive a motor?  I thought pulse width modulation for motors was just for DC power.
« Reply #4 on: August 29, 2009, 07:34:44 PM »
im not too sure, but most relays can switch both...
Offline Daanii
« Reply #5 on: August 29, 2009, 08:36:21 PM »
That makes sense.  No reason why a relay that could handle AC power could not handle DC power.  Using relays to make an H-bridge is a clever idea.  Not something I had ever thought of.
Offline mack33
« Reply #6 on: August 29, 2009, 10:00:59 PM »
From the datasheet:
I think I found the specific data sheet that you were talking about. It appears that the max turn on time and turn off time are 10ms not .5ms.
Is this the correct data sheet? http://futurlec.com/Relays/SSR40A.shtml
If I am correct, I'm pretty sure it's to slow.
« Reply #7 on: August 29, 2009, 10:03:21 PM »
Strange, Datasheet has different info. I attached it.
« Reply #8 on: August 30, 2009, 06:51:32 AM »
Why don't you break out your calculator for a quick run down of the available data, when you think you've found the Holy Grail, instead of starting a discussion that's a waste of time, since it's so easy to see that it's not doable?
The AC SSRs cannot switch DC!
The DC SSRs on the bottom of the page (priced $21.90 and $27.90) can switch DC but with the 0.5ms max on/off switching times.
That means that the max. frequency to design with is 1kHz and then there's nothing left for PWM.
To do useable PWM on them, you'd need to settle for a PWM frequency of around 10Hz tops, to make the switching times negligible.
IOW, you cannot use these SSRs for H-bridges (unless you're trying to build a Senior Citizen Clone  ;D).
Offline Daanii
« Reply #9 on: August 31, 2009, 10:53:56 AM »
Better to put out an idea for others to think about than to stay silent.  Even if the idea doesn't work, it is clever.
Transistors did not always switch at nanosecond rates.  Relays have a long way to go to work fast enough, as you point out, but who knows what the future will bring.  These solid-state relays are pretty remarkable compared to their mechanical forebears.
« Reply #10 on: August 31, 2009, 04:12:15 PM »
[...] Even if the idea doesn't work, it is clever.
What clever is there over something that doesen't work? (Besides that you just created a new oxymoron).
Sure, and perhaps mankind will travel to another planet someday, but I find it utterly pointless telling that once we hunted with sticks and that we don't know whether we will hunt with target locking LASERs someday. I tend to work with what's here and now, as it's what's here and now!
« Reply #11 on: August 31, 2009, 04:22:19 PM »
You are in a life or death situation. Kidnapped by evil people, you are trapped. The only way to escape is to create a small robot that is laden with explosives, which will travel to the evil people and detonate. The problem is, there are no MOSFETs to be found. You panic. You die.
Or, you remember this thread, and find some DC SSRs lying around. You remember that the PWM frequency issue, so you lower it. The robot works, the evil people die, and MacGyver sends you an autographed picture.
« Reply #12 on: August 31, 2009, 10:29:02 PM »
Trapped, so (worst case) it has to be a potential life or death situation.
Nah, I use a paper clip or similar to make a contact B+ to M+ since there's no reason for going slow when you deal with baddies.
Had the evil people been stupid enough to leave DC-SSRs when sweeping for MOSFETs, they probably can't kill a worm, so no worries ;)
So I don't even have to break open the SSRs to get to the MOSFETs inside and neither do I have to kill the baddies.
Only if I don't kill anyone I believe - not that I really want a piccie of McGuyver, the master-wuss of them all, autograph or no ;D
But he's got more pressing things to ponder anyway...
They can't spell either ;D
