Author Topic: Current available from power supply  (Read 754 times)
Offline KerryTopic starter
« on: August 31, 2009, 08:44:08 PM »
Hello,
I'm trying to design a battery charger.  Based on various articles and the capacity of the battery, I figure I'll need ~2A during the "rapid" portion of the charge.  My batteries are 6V, I'll supply a little over that to charge at the peak.  If I use a 12V power supply, and it gets regulated to 6V, how many amps do I need.  If it supplies 1A at 12V, do I get 2A after the voltage is regulated to 6V (or close to it, if it's not 100% efficient), or does the excess voltage go mostly to heat?
Is my question understandable?  Not sure if I'm asking correctly...
Thanks,
Kerry
Re: Current available from power supply
« Reply #1 on: August 31, 2009, 10:37:26 PM »
With a linear supply you get 1A.
With a switching DC-DC converter you will get somewhere between ((12*1)/6*K) where K is the efficiency of the switcher, which may be anywhere from around 60% to say 95%
You have to first define which cells you're gonna use and how many, then you can calculate the needed voltage - don't assume 6V plus a little for good measures if you want your charger to work.
« Reply #2 on: September 01, 2009, 06:17:18 AM »
Does this mean the rest goes to heat?  So I'd be better of with say a 9V supply than a 12V supply because the 12V supply will just make the regulator get hot?
Can you elaborate?  I plan on using the - delta V technique to determine when the batteries are charged - so in practice I will only be limited by the power supply.  But I don't understand what you mean when you say "which cells" I'm going to use and how many.  I have 6V NiMH battereis (5 cells each).  Are you implying that I can charge only certain cells, or just that I need to know what battery I want to charge?
Thanks,
Kerry
« Reply #3 on: September 01, 2009, 07:43:54 AM »
Exactly!
Oh, you got it :)
Different chemistries have got different end-of-charge voltages, so knowing which you've got is important if you want minimum possible losses.
As above, assuming you want to make a charger for your particular batteries without wasting too unnecessary power.
5 NiMH cells will have and end-of-charge voltage of ~7.40V to 7.45V when fast charging at around 1C (i.e. 2000mA for 2000 mAh cells) and it will take around 66 minutes to fill a totally depleted cell.
You'll have to allow for voltage drops in the current switching element, whether it be a transistor, a relay or whatever and you'll have to allow for mains voltage variations as well (assume a drop of ~10% worst case).
If your switching element have a drop of say 0.5V, you'll need a supply of around 9V ((7.45+0.5)*110% = 8.75V) for your 5 NiMH-cells.
Are you perhaps using a MAX712?
If not, at least read through the datasheet at http://www.maxim-ic.com/getds.cfm/pk/1666, it will give you a better understanding on the subject.
« Reply #4 on: September 01, 2009, 08:04:09 AM »
Great info!  Thanks for the help!
-Kerry
Last post July 24, 2009, 01:51:28 PM
Last post February 19, 2010, 04:00:32 PM
by Webbot
Last post February 04, 2011, 09:24:08 PM
Last post November 03, 2011, 02:32:21 PM
by Mastermime
